Lincoln AC225 S
发表于 2021-9-1 23:19:10 | 显示全部楼层 |阅读模式
Hi all, my first post on your page... well I can't seem to locate info. using my code: 8712-705 I need DC to use 7018 rod so I bought a 300amp full wave rectifier. will age have any effect on the transformer adding this rectifier?  I rarely use this welder only projects in the garage. 1/4in. Fillet welds, Lap Joints. Thanks for your advice.
Reply:It would be a lot easier to just buy a box of 7018 ACLincolin Power Wave 450, Lincoln Powermig 255, Lincoln Pro Mig 140, Lincoln Squarewave Tig 275, Miller Big 40 G(with Hobart Hefty suitcase), Thermal Arc 95S and Esab PCM875 in an already full machine shop.
Reply:I watched a guy weld using AC 7018 Rod on his Lincoln AC225. after he installed a Rectifier and welded it was a big difference, the flow was better, less splatter as well. I was mainly trying to find info. on my code. the video was on YouTube. thanks
Reply:You will need an inductor to go with the rectifier to stabilize the DC arc and a noise suppressor. Using the AC rod will be a lot cheaper.I have an old 300 amp Glen stick welder that has higher OCV. It burns anything I try.and welds great. Have used it to repair a lot of farm equipment.
...so I bought a 300amp full wave rectifier..
Reply:It can be done but I would suggest buying a Miller Dialarc 250 or Lincoln Idealarc250 and be done with it. Nothing experimental about those machines. Unless you just want to do a conversion project. Sent from my iPhone using TapatalkSteveMiller Dialarc 250 (1990)Miller Maxstar 140 STR (2003)Lincoln SA200 Redface Pipeliner (1966)Lincoln MP210 (2015)Victor and MECO torches
Reply:Is this the smaller counter top AC 225S? Not worth even trying to convert it to DC.
GMT+8, 2025-12-20 12:21 , Processed in 0.087388 second(s), 18 queries .
