Shorthood oil pressure
发表于 2021-9-1 23:19:06 | 显示全部楼层 |阅读模式
I just got a new to me shorthood and got it running for the first time in who knows when. I changed out the anti freeze and oil put a new carb on it and tried starting it to see if the motor had any life. It fired up after about the 3rd rotation of the starter oil pressure is 40 psi is that something to be worried about?
Reply:Spec for the F-162 is 7# min and 20-30# max.  For the later F-163 is the same min and 30-40 max.  I wouldn't give it another thought.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110
Save Second Base!
Reply:Awesome thanks.
GMT+8, 2025-12-20 12:20 , Processed in 0.092432 second(s), 18 queries .
