Bobcat 225 spec h Subaru engine
发表于 2021-9-1 23:19:03 | 显示全部楼层 |阅读模式
Subaru engine LKO21476h Not getting fuel to the carb. Looks like the fuel pump is working and after cranking there’s gasoline running from a small black tube under the carb. Thanks Well I poured a little gas down the carb and it started running. I’m going to put it back together and try to run it.Last edited by Kpack; 11-01-2020 at 04:12 PM.
Reply:I have not pulled the carb. I’ll try that . I know I had a old bobcat and there was a screw on the side where you could drain it but this carb is different.
Reply:I have a bobcat with a subaru motor in the shop right now... was going to grab some pics for you yesterday but didn't have time....not all the different fromkohlers/briggs,etc...
Reply:Did you just get this machine  ??? Many Subaru's for some reason may need a shot of either to start. After starting, they run fine. Sent from my iPhone using Tapatalk
Reply:No I’ve had this machine for several yrs.  I don’t know this carb but when I get time I’m going to go through it. Thanks for the replies
Reply:The needle screw beside the solenoid must be a drain when I open it a little bit that’s when gas runs out the bottom tube.  Pulled that screw and the solenoid and blew some light air in it to clean it out.  It’s running ok but I probably need to pull the carb. Thanks everybody
GMT+8, 2025-12-20 12:46 , Processed in 0.070913 second(s), 18 queries .
