miller bluestar 2e parts
发表于 2021-9-1 23:19:02 | 显示全部楼层 |阅读模式
Does anybody have an old 2e laying around?  I need the CT1 miller part number 080870.  Its the control idle transformer. Or anybody know where i can get one?
Reply:Have you tried miller4less.com?You will need the part number for what your looking for. If what your looking for isn’t there, often parts can be had elsewhere sometimes.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:When you say 'transformer' do you mean the pickup coil they have going around any of the current supplying conductors? or do you mean the amplifier part of that circuit?The pickup coil would be fairly generic to other similar welders and although I do not know the specs I would bet substituting wouldn't be too hard.
Reply:Do you have the original or is it missing altogether?  If you have the original, I would suggest rewinding it yourself with the appropriate gauge/length of magnet wire if you can/have confirmed there is an open in the existing winding.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110
Save Second Base!
Reply:If you don't have the spec already, CT1 output should be 27VAC with a 50A weld load.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110
Save Second Base!
Reply:Does anybody know where i can get this part repaired or rewound?
GMT+8, 2025-12-19 14:55 , Processed in 0.128677 second(s), 18 queries .
