What are the advantages of handheld laser welding machine? What's the price?
管理员
Rank: 9Rank: 9Rank: 9
发表于 2021-6-11 14:46:51 | 显示全部楼层 |阅读模式
图文
图文封面:
Laser welding technology is a new welding technology and a popular welding technology in the market. Laser welding machine is also called laser welding machine and laser welding machine, which is a welding machine for laser material processing. His principle is to use high energy laser pulse to heat the material locally in a small area. The energy radiated by the laser is guided by heat transfer to the internal diffusion of the material, and then the material is melted to form a specific melting pool.
Laser welding is a new type of welding method, most of which is aimed at the welding of thin-walled metal materials and precision parts. Its advantages are that the welding speed is fast, the welding quality is good, the weld is smooth and beautiful, the weld is small and has no porosity, and can be controlled accurately. After welding, no secondary treatment is needed, and the welding can be realized, such as spot welding, butt welding, overlap welding, and sealing weld fillet welding, etc., with little deformation, The welding seam has good sealing property, small focus light point, high positioning accuracy, and it is easy to realize automation.
What are the differences and advantages between the hand-held laser welding machine and the automatic laser welding machine and welding robot? General electric small edition to give you analysis
When purchasing laser welding, the buyers will generally go to the laser manufacturer to customize the production according to their own product performance requirements, but there will also be some standard production models. In this link, a few processing processes can be selected and used. Whether it is a hand-held laser spot welder or a fully automatic laser welding machine and welding robot, the welding requirements of the products can be realized.
1. Hand held laser welding machine
The hand-held laser welding machine said that it is a laser welding equipment that needs manual operation. Such laser welding equipment can carry out laser welding of long-distance and large product workpieces. During welding operation, the heat affected area is small, which is not easy to cause deformation, blackening and printing marks on the back side of the product. Moreover, the welding depth is large, the welding is fixed and the melting is sufficient, There is no dent in the joint between the protruding part of the solution and the matrix. The welding speed is fast, the welding quality is good, the welding seam is smooth and beautiful, the weld is small and has no porosity, and can be controlled accurately. After welding, no secondary treatment is required. It can realize spot welding, butt welding, overlap welding, sealing weld fillet welding and other welding
2. Automatic laser welding machine
Automatic laser welding machine is a kind of automatic laser welding equipment which does not need manual operation. Its working principle is to use high energy laser pulse to carry out local heating in small area of material. The energy radiated by laser is diffused through the heat transfer to guide the internal diffusion of material, and then the material is melted to form a specific melting pool. It is mainly aimed at welding thin-walled metal materials and precision parts, which can realize fillet welding, butt welding, spot welding and overlapping welding sealing welding. It has the characteristics of small weld, fast welding speed, stable and fixed welding, high welding quality, good sealing without porosity, precise control, high positioning accuracy and easy to realize automation.
3. robot laser welding machine
Automatic laser welding machine and welding robot are all programmed in the programming software and welding is carried out automatically according to the set procedure; And the manual laser welding machine is also called spot welding hand welding, which is manually amplified to screen through high magnification to carry out visual spot welding.
Compared with the automatic laser welding machine, the advantage of manual laser welding machine is that manual laser welding has more flexible and convenient advantages in dealing with the production workshops of scattered processing or non-large-scale processing welding, and it is not necessary to set and debug, but the fully automatic laser welding platform and space environment are required, What's more, the materials of the small processing plant are diversified and the shape is not fixed. Therefore, the artificial laser welding can satisfy the demand of this kind of production and has better flexibility.
Guangdong Pudian Automation Technology Co., Ltd. is a professional manufacturer of welding equipment. For 16 years, it has focused on R & D and sales of spot welding machine, laser welding machine, non-standard automatic welding machine, welding robot and other welding equipment. Pudian welding machine focuses on the field of metal welding, saving energy and reducing consumption, improving welding quality and improving welding efficiency, Reducing the cost of welding is our fundamental service to customers.
Free proofing hotline:+86-13553885280
Address: Zone B, 1st floor, C-1, No. 6, industrial North Road, industrial park, Songshan Lake high tech Industrial Development Zone, Dongguan, Guangdong Province, Tel: +86-769-81767569
本帖子中包含更多资源
您需要 登录 才可以下载或查看,没有帐号?立即注册
x
GMT+8, 2025-12-17 04:12 , Processed in 0.078479 second(s), 21 queries .
