Roughneck 1E no power output need help
发表于 2021-9-1 23:18:55 | 显示全部楼层 |阅读模式
i have a roughneck 1e that has been sitting 5 years. i have it running but am getting no ac  or welding output. is there anyone near Waco, tx that works on these. thanks
Reply:i am still needing someone close to Waco to work on my roughneck. thanks
Reply:I had the same issue on a 1e.  Check the weld power switches.  If they are functional test the diodes on the circuit board.  I replaced a couple bad diodes and it was good to go.
Reply:Ask your local welding supply. I know one in north zulch  Tx but I’m not sure about Waco.
Reply:great idea thanks
Reply:The Roughneck welders have slip rings. Since bend sitting 5 years the rings will have oxide and this will give no power.Simple to clean slip rings with 120 to 200 grit paper. Dave
GMT+8, 2025-12-20 12:22 , Processed in 0.088598 second(s), 18 queries .
