Question On AWS CWI Certification Exam Study Materials
发表于 2021-9-1 23:18:50 | 显示全部楼层 |阅读模式
I want to get AWS CWI certified.  What study materials should I use?  Is there a practice exam?  Where can I buy the study materials at cheap price?  Would prefer to not buy from AWS because prices are high.Thank you,BennyB
Reply:Sign up for the seminar and have the books shipped out several months in advance. I did it that way and it made the seminar and test simple.
Reply:I self studied using "AWS Welding Handbook Volume 1", "Certification Manual for Welding Inspectors" and various code books I had at the time.The above books contain most of the subject matter on the CWI exam or at least it was enough for me to pass. The problem is that unlike a course specifically designed to assist with passing a test, you have to read and absorb much more. If you have time for self study and are interested in the subject matter than it may be easy . If your sole intent is to pass the test but you have not cracked open many welding or inspection related books until now, a course may be the answer. Never took one myself but have hear mixed reviews on many of them.GeraldHave a nice dayhttp://www.weldingdata.com/
Reply:Here's a list very comparable to what you'd be given in a seminar:Either the API-M API 1104 Study guide, or the D1.1 equivalent from AWS.AWS Certification Manual for Welding Inspectors *if you could only have one, this would be it.AWS VIW-M Visual Inspection Workshop ManualAWS WI Seld INspection HandbookAWS WIT-T Welding Inspection TechnologyAWS WIT-W Welding Inspection Technology WorkbookAs for buying at a cheap price... forget about it.  I just compiled this list the other day so my company could order a few copies to train people ourselves rather than send them to the seminars.
Reply:Thank you for the many good answers.One more question....My question on the exam.......Are you tested on all three, (1) API-M (2) API 1104 and the (3) D1.1?  Or do you choose before hand what section to be tested on?  If you only chose 1 section, what is most easy?  So if I just only 1 I only need to purchase the book for that section?  I don't understand this aspect of the exam.Regards,BennyB
Reply:You will select a specific code book to test on. You will have to have the actual code book and edition. Photocopies are not allowed as far as I know.There is no "most easy" that I am aware of. Whatever code you are most familar with would be the one suggested .Have a nice dayhttp://www.weldingdata.com/
Originally Posted by jakobj
Where I can buy a book with training questions and answers for AWS CWI certification exam?
Reply:If you have not bought your books yet, go to the AWS website forum and search for used books.  You will be able to save money that way if there are any for sale.
Reply:There is no inexpensive tech books affiliated with AWS out there that I know of. I suggest to bite the bullet and purchase them or if you can borrow them for the test the better. I say purchase because they will become part of your library in the future,n't and would you buy best for an important job which you are doing. Use a code book which you are familiar with and have worked with, you can use any code book which AWS recommends but I would stick with one you know. The test is to assure you understand how to navigate through the various code books out there you will be qualified for them all with just one test.Hope this helps you out a little and best of luckWeldor/ Certified Inspector
Reply:You guys that got your books shipped out before the exam - did you just ask for them to do that?  I'm signed up and paid for the Atlanta one in March, and would definitely like to get the books before the exam to get more familiar with them...
Reply:Hi, where should I buy book from?
Reply:Might want to try thepiratebay or isohunt.  I got some AWS books off a torrent site months ago, I don't have the clams to buy expensive tech books without a plan to take the test anytime soon.  Won't help you if you need the actual books for the test but its a thought.
Reply:I have only written one code test.  The most helpful thing I did was to put tabs on the important pages so that you could find the relevant section.  Most are open book tests which are difficult since often you have to cite or find the correct clause or passage.  Also putting the tabs on and deciding where to put them is a form of study.
Reply:1) You should first figure out what code you want to test on, 2) Purchase the code books that AWS is going to test you on. 3) Check at this website: www.weld-procedure.com and tell them [email protected] sent you. It is a self paced online coarse that is what you put into your study time! You should do just fine.
Reply:I have the part A exam Pattern in My hand
Reply:i will give the question pattern
Reply:I will give the qns pattern for part a
Reply:I would imagine that the CWB testing procedure is nearly identical.  given both CWB and AWS acknowledge each others qualifications.  ...I have only written one code test. The most helpful thing I did was to put tabs on the important pages so that you could find the relevant section. Most are open book tests which are difficult since often you have to cite or find the correct clause or passage.Also putting the tabs on and deciding where to put them is a form of study...
Reply:I think i have some practice test CWI questions too, if anyone wants.rupe01I would appreciate a look see at those.email:  ramadidave @yahoo.commardad
Reply:Can ypou forward on the part A exam
Reply:Please forward them onto [email protected]. Thanks
Reply:I too am looking for practice questions and study material.  I would greatly appreciate it if anyone can please forward me any useful material.   I am particularly interested in material from the 2008 WIT book to assist with part A.  Anything for part B would also be useful, or anything else that may help.  Thank you in advance! My email address is: [email protected]
Reply:I am also interested [email protected] Greatly appreciated thanks in advance.
Reply:do you have questions regarding part b
Reply:I would appreciate any questions pertaining to part b. [email protected]
Reply:Can u tell me which open books I will be using?  I'm taking the API 1104 exam but will that code book be used opened during the exam, the part B book (fake codes I'm told), or both used open during the exams???
I called Fla. and talked to a nice lady that boxed and shipped them that was in 1992
Reply:So you have to have a job first in order to take the exam?
Reply:You have to have a minimum amount(5 years off the top of my head) of verifiable real-world experience.  College will count towards some of the minimum, but not all.The advice I can quickly pass along is:  IF you think the answer to any of the multiple choice questions on the exam sections might be "None of the above", then go over that question again after you reach the end of the section.  The odds of this answer being the correct one to any question are very low.  Beware of the questions with answers like, " A,  A and B, or A, B, and C ".  These deserve extra special attention to ensure that you select the best possible answer among the choices offered.Last piece of advice, pay attention to the footnotes in any code book you use in the test.  The devil is in the details, and the AWS wants to know that you as an inspector are attentive to the smallest details.Benson's Mobile Welding - Dayton, OH metro area - AWS Certified Welding Inspector
Reply:Am new to the board!! Rookie welder--2yrs experience in production welding...stainless and carbon and inconel..would like to be cwi certified plz anyone with exam questions would be greatly [email protected]
Reply:I just called the AWS and asked if they would send me the books prior to the seminar week and they said, "they don't do that, nor have they ever did it that way". Can you please tell me how you were able to get the study material prior to the Seminar and Exam week? Thank you!
Reply:could u email what u have?
Reply:please forward any info you have to [email protected] thanks!!
Reply:ive got lots of books and study material if anyone needs it
Reply:I have the Certification Manual for Welding Inspectors and the Welding Handbook. I'm just not sure what else I really need to look over and study? Please get back to me about the study material. Thank you.
I could definitely use them. I have the Certification Manual for Welding Inspectors and the Welding Handbook. I'm just not sure was else I really need to look over and study. Please get back to me about the study materials. Thank you!
Reply:this is what I haveAWS A2.4:2012-STANDARD SYMBOLS FOR WELDING, BRAZING, AND NON-DESTUCTIVE EXAMINATONAWS A3.0:2010-STANDARD WELDING TERMD AND CONDITIONSAWS B1.1:86 THRU 09-GUIDE TO THE NONDESTRUCTIVE EXAMINATION OF WELDSAWS B5.1:2003-SPECIFICATION FOR THE QUALIFICATION OF WELDING INSPECTORSCERTIFICATION MANUAL FOR WELDING INSPECTORS (OLDER VERSION WITH TESTS AT END OF EACH CHAPTER...)AWS D1.1:2010-STRUCTURAL STEEL WELDING CODEAWS CWI EXAM PART B PRACTICE TESTAWS QC1:2007-STANDARD FOR CERTIFICATION OF WELDING INSPECTORSAWS WELDING HANDBOOK VOL1-5WELDING VISUAL INSPECTION WORKSHOP AWS VIW-M:2008-VISUAL INSPECTION WORKSHOP REFERENCE MANUAL.AWS VQIM-W:98- WELDING QUALITY ASSURANCE WORKBOOK.WELDING INSPECTION TECHNOLOGY SAMPLE CWI FUNDAMENTALS EXAMINATIONCWI FLASH CARDSTHE OFFICIAL BOOK OF D1.1 INTERPRETATIONSAWS WIH:2008 WELDING INSPECTION HANDBOOK AWS WIT-T:2008 WELDING INSPECTION TECHNOLOGYAWS WIT-W:2008 WELDING INSPECTION TECHNOLOGY WORKBOOKAPI 1104^^^ THIS IS THE REFERENCE MATTERIAL I HAVE FOR THE CWI EXAM AS WELL AS OTHER PRACTICE TESTS AND FLASH CARDS I PULLED FROM ONLINE I ALSO HAVE COMPLETE AWS LIBRARY OF A,B,C, AND D BOOKS API 1104, 510, 570, 572, 510 ADDENDUM 3&4, 5L, 580, 598, 620, 650, 653, 910, 1632, 2218, SPEC 12D, 8C, 526, 527, 660, 576, 661, 662, 2201, RP510, RP520-521, RP574, RP578ANSI H35.2, IS1A Z49, Z540, NCSL Z540-1, BI6.5FULL LIBRARY OF ASME BOOKS (TOO MANY TO LIST)ASTM BOOKS (AGAIN TOO MANY TO LIST)CALTRANS BOOKSCBC BOOKSCSA CODESDSA CODESFEMA CODES FIRE CODES FIRE PROOFING CODES GREEN BOOK HVAC BOOKSIBC BOOKS IEBC BOOKSIECC BOOKSIFC BOOKS IFGC BOOKS IMCIPCIRC ISO ISPSCMETAL STUD FRAMING NACENATIONAL ELECTRICAL CODE NEMANETA NFPAOSHAOSHPDSJI-STEEL JOIST MANUAL SDI BOOKSUL UBCUS MILITARY CODES WDMA ...... YOU NAME IT IF I DONT HAVE IT I CAN PROBABLY GET IT!!!!.........email me if interested [email protected]
GMT+8, 2025-12-20 18:45 , Processed in 0.108386 second(s), 18 queries .
