Looking for Carb for sa200 F162 with vacuum idler
发表于 2021-9-1 23:18:43 | 显示全部楼层 |阅读模式
Looking for a rebuilt or used replacement carb for SA200 f-162.  I,m trying to see if this welder is worth putting any money into it without spending 400$ on a new carb just to see if it will weld. A brand new from weldmart is 398.50 + tax so if anyone has a lead on one I could sure use it. The one on the machine is junk and it is a Marvel Schebler TSX514, thanks
Reply:Maybe see if someone like Stump's or Bill's Welder Repair has a used carb. With an F162 I'd guess it's a redface so is desirable if it works and maybe even if it doesn't.
Reply:Those old carbs are pretty tough, try a good cleaning.https://www.instructables.com/Electr...val-aka-Magic/
GMT+8, 2025-12-20 18:19 , Processed in 0.103132 second(s), 18 queries .
