Rubber seal for lifting eye?
发表于 2021-9-1 23:18:42 | 显示全部楼层 |阅读模式
looking for a source for the rubber seal that fits around the lifting eye on the top of my Ranger 9. thanks!
Reply:If you can't find anything, you can try a truck tire shop and ask for a piece of old innertube???"Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!
" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:What about something like this
Reply:I just looked in my Ranger 8 parts manual pdf and it isn't shown.  Have you tried calling Lincoln?  They have found parts for me before that were not listed in any available publication and which dealers and service centers had told me were no longer available.Best regards and good luck,LanceMultimatic 255 w/MDX-250 EZ-Select gunHypertherm Powermax45 XPHeck Bevel Mill 4000Miller/Smith heavy duty torch set9" Evolution circular saw
Reply:It will take some work to cut out the center slot but go find some skirt/flashing rubber at an aggregate plant. They probably have some used stuff you could use.Ol' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:Many thanks for all replies! Found it from Lincoln after a long phone search by them. Part # S12934-1  $4.19
Reply:A good source for part inquiries is Stumpf Welding Supplies.  Been around since 1952.https://stumpfweldingsupplies.com/Also Welding Supply (since 1950). https://weldingsupply.com/cgi-bin/ei...UNDEF:X:S12934 Did you get that one from Bill's Welder Repair?Last edited by Oldendum; 01-22-2021 at 01:04 PM."USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:Lincoln had it in stock. thanks for the sources and your sacrifice!
Reply:https://www.shoppok.com/milwaukee/a,...EST-ALLIS-.htm check this. Not mine.
GMT+8, 2025-12-20 18:23 , Processed in 0.084444 second(s), 18 queries .
