Miller Dialarc 250, Minneapolis, $275 obo
发表于 2021-9-1 23:18:39 | 显示全部楼层 |阅读模式
70's model Dialarc, nice welding machine.  Welding leads are possible with some negotiating
$275 obo(218) 556-3316 (cell)[email protected]
Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:Anybody looking for good proven welding machines, these are fire sale prices. Don't wait or they will be gone.
Reply:Nice and good price, less than $1/lb..  I have one just like it from 1974, one of the earliest ones made with an HD serial number."USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:HD is 73. First year they used the letter date codes. J codes for the 80's start at JA for 1980. Funny Miller doesn't use I in date codes. Maybe so it doesn't get confused with a 1?
Reply:They are great machines for sure. I had one for several years then back to a Lincoln Idealarc250. I’m just a Lincoln guy I guess, both machines are better than I am. Lol. Sent from my iPhone using TapatalkSteveMiller Dialarc 250 (1990)Miller Maxstar 140 STR (2003)Lincoln SA200 Redface Pipeliner (1966)Lincoln MP210 (2015)Victor and MECO torches
I found this picture of mine. It was a 1980 Blackface. I had the custom tread plate hood made for it. Smooth welding machines Sent from my iPhone using Tapatalk
Reply:They did a great job on that top
Reply:Wow, that's a steal!  I haven't seen a decent one under $500 in quite some time.Check out my bench vise website:  http://mivise.comMiller Syncrowave 250DXMillermatic 350P with XR AlumaProMiller Regency 200 with 22A feeder and Spoolmatic 3Hobart Champion EliteEverlast PowerTig 210EXT
Reply:That's likely just a later version of the manual and the machine hasn't changed from late 73 models.https://www.millerwelds.com/support/serial-number-chart
Reply:The first ones were white face with little rectangular holes in the front panels instead of the louvres Sent from my iPhone using TapatalkSteveMiller Dialarc 250 (1990)Miller Maxstar 140 STR (2003)Lincoln SA200 Redface Pipeliner (1966)Lincoln MP210 (2015)Victor and MECO torches
Like this Sent from my iPhone using Tapatalk
Reply:How much for the machine with leads and everything? Also how much does it weigh?
Originally Posted by MinnesotaDave
The plug is wired up and it's ready to plug in and weld.  Test it any time.Weight is around 350-375 lbs as I recall - it's an industrial machine.Leads depend on what you want.  Light duty leads aren't very expensive and this set goes to 200 amps at 100% duty cycle.  Which means you won't overheat them even at max with this machine.https://store.cyberweld.com/howecase...rce=googlebaseIf you want heavier/longer leads, I can include them, but they can get expensive depending what you want.
Reply:If you are anywhere near Dave, it would be worth the drive.  Go on a "field trip" as my wife often says.....
Reply:I'll include a set of 25' 1/0 cables for package price total $395.Wired up, ready to plug in and work
Last edited by MinnesotaDave; 02-09-2021 at 10:08 PM.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:I sold a Dialarc 250HF to a fellow in Ohio?, if I remember. Mine included a TIG outfit along with cooler & 50' leads. It sticks in my mind it cost $190 to ship. Guy was here, called himself Tuscany. Maybe his memory is more accurate.An optimist is usually wrong, and when the unexpected happens is unprepared. A pessimist is usually right, when wrong, is delighted, and well prepared.
Reply:What is your zip code? Maybe I'll get some shipping quotes
Reply:I've researched a bit and read that this machine would require around 80 amp service to run well.  Could I even run it off of my dryer outlet?
Reply:Not a dryer outlet but a 60 amp or maybe even a 50 amp would work if you're not at the top end.
Reply:I’ve always ran my Dialarcs and Idealarc250’s on 50 amp service and not had any issues Sent from my iPhone using TapatalkSteveMiller Dialarc 250 (1990)Miller Maxstar 140 STR (2003)Lincoln SA200 Redface Pipeliner (1966)Lincoln MP210 (2015)Victor and MECO torches
Reply:While we are discussing Miller Dialarcs. I have ran and owned Dialarcs and Lincoln Idealarc250 welders, it seems to me that the Miller has a less aggressive, smoother sounding and appearing arc. I have a Lincoln now and I prefer the arc characteristics it has slightly, both are wonderful machines and both will weld better than I can.  I’m wondering if this difference is due to the range switch on the Miller that changes the arc voltage at the same amperage setting. According to the manual it’s only 2 volts, 27 vs 29. I know my SA200 really allows this go up a gear and down on the volts and get a stiffer puddle. What do you guys think?Sent from my iPhone using TapatalkSteveMiller Dialarc 250 (1990)Miller Maxstar 140 STR (2003)Lincoln SA200 Redface Pipeliner (1966)Lincoln MP210 (2015)Victor and MECO torches
Reply:Damn.... Bemidji is only 4.5 hrs if they'd let me across the border. That's tempting...250 amp Miller DialArc AC/DC StickF-225 amp Forney AC Stick230 amp Sears AC StickLincoln 180C MIGVictor Medalist 350 O/ACut 50 PlasmaLes
Reply:Sold Canadian
Thanks
Reply:Canadians know a good deal when they see it.
Reply:Will you say, or do I have to ask Wheat? I was saddened when he went all out to repair a Twentieth Century rebadged Sears. Now he begins to learn.An optimist is usually wrong, and when the unexpected happens is unprepared. A pessimist is usually right, when wrong, is delighted, and well prepared.
GMT+8, 2025-12-20 18:44 , Processed in 0.088899 second(s), 19 queries .
