Miter Cut Calc Spreadsheet
发表于 2021-9-1 23:18:30 | 显示全部楼层 |阅读模式
Hi all,I created a spreadsheet for calculating a few things regarding angles and miters.Knowns:- Envelope (Length and Width)- Tube size (1" square, etc)- Guesses on starting anglesCalculated things:- How long to make each tube- What the miter cut angle isAdd'l things the user has to do:- Mess with the plot's x and y so that the graph is a square.  (pretty easy)- Convert the calculated length of tube into a fraction / close as possibleI guess this sounds more complicated than it really is.  Check it out and let me know what you think.  Below is a screenshot of the plot.  I think the plot is pretty useful.I was using this because I wanted to make a 'bent' leg on a bistro table.  I knew the table top dimensions (24" x 24") and I knew the height of the table (42") and I knew I was going to use 1" tube.  This program made it easy to figure out what cuts to make.  Hope you find it useful!Attachment 1433091PS: I had to use a ZIP folder to attach to this forum.
Miter Cuts.zip (13.9 KB, 35 views)Last edited by engineer1984; 06-01-2016 at 12:35 PM.
Reply:My step brother updated it to include fractions instead of awkward 18.512840 blah blah numbers.Here you go!
GMT+8, 2025-12-19 17:11 , Processed in 0.094755 second(s), 18 queries .
