Wow!!
发表于 2021-9-1 23:18:23 | 显示全部楼层 |阅读模式
And you guys wonder why I spend an inordinate amount of time repairing my old junk.  We're a cheeeeezy little cow/calf operation, and most decent stuff is absolutely out of our price range...…...so it's old crap here at the compound.First off...…...compared to a new one......it's a pretty reasonable price.Second...….I find it obscene that the thing went to someone who won't even use the dam thing
Third...…...the way the things are made these days, a guy CANNOT work on them.  Everything is computerized, and the dealer rapes ya with proprietary software.  This is driving the used market thru the roof
  Little guys, like me, are being priced out of the market.
Reply:This is more in our league,, and it's still high.  Both my 190xt's were about 3500 each.
Reply:Wow Sammm, you're lucky to be able to afford something as new as you got ... my personal stuff is a bit older... but I can still make it run(sometimes)
Reply:I saw a news clip a few days ago that said farmers were going with the older equipment because it could be repaired, unlike some of the new stuff.  It sounds like that must be correct.
Reply:Totally agree on the computerized crap.  Just had my truck go through this with a check engine light showing trouble codes for a lean fuel problem. Turned out it was the barometric readings from the mass air flow sensor under-reporting the air volume to the computer.  This was after the dealership diagnosed the problem as a failing fuel pump.  Sheesh, how complicated does this stuff have to get ?
Reply:My work truck has been running really rich ultra high idle for a little while now, so I finally got a chance to put a code reader on it... didn't see much til I scrolled down at the temp... sensor was telling the motor it's coolant was forty below!!!!Easy enough to change once I removed the air intake ducting but just shows you how one little POS sensor can mess up a good engine.
I have the manuals on my trucks, and God are they a life saver.  My specs show different readings for different baro's on the MAP.  You just match the cycles with the baro to see if you're in tolerance.  Mine is pre MAF, and just has MAP.  I think both of my motors were **** canned because they couldn't meet EPA standards after the 90's.
Reply:A buddy of mine manages several large farms in the Phoenix area, he has a fancy relatively new harvester that recently quit working, wouldn't do ANYTHING! He finally got a field tech out to troubleshoot it and it turned out to be something with the air conditioner or HVAC on the thing, probably has something to do with keeping the cab pressurized for safety reasons, this computer controlled crap can drive ya nuts!IMPEACH BIDEN!NRA LIFE MEMBERUNITWELD 175 AMP 3 IN1 DCMIDSTATES 300 AMP AC MACHINEGOD HELP AMERICA!“Freedom is never more than one generation away from extinction.We didn’t pass it to our children in the bloodstream".RONALD REAGAN
Reply:I have JD 4440 with only 3600 hours. It's hooked to a 20' batwing mower and only gets used for clipping pastures and mowing road ditches. I keep it inside and run it for a bit every month in the off season, just to keep things working. After looking at some auctions in RFDTV, there's no telling what it's worth...
Reply:I wouldn't have a problem bidding up to $28k Cdn. on it ( current exchange puts us at .765 US). Depending on the day I'd say it would bring $28 to $42k Cdn.250 amp Miller DialArc AC/DC StickF-225 amp Forney AC Stick230 amp Sears AC StickLincoln 180C MIGVictor Medalist 350 O/ACut 50 PlasmaLes
GMT+8, 2025-12-20 18:20 , Processed in 0.103484 second(s), 18 queries .
