Hobart RC300 3ph to 1ph?
发表于 2021-9-1 23:18:14 | 显示全部楼层 |阅读模式
Have a line on this hobart rc300 tag says 3 phase, can these be changed to single phase? Its only 200 bux with wire feed goodies , it would be a stinking bargain, but i can't get 3ph here at home.Trying to post pic off id tag
Reply:Yes it can be converted to single phase.https://www.practicalmachinist.com/v...ersion-258706/
Reply:I like Hobart welders I own 300 amp stick welder and a G213 stick welder.You can run on motor conerter.But sometimes it can be pain for anyone does not have a background in electronic or electrical I would look for single phase welder. If you here Clovis California I could help the covering over single.Dave
Reply:FYI To cover to 3 phase you need to disconnect the three transformers each other on this welder.Dave
GMT+8, 2025-12-20 18:23 , Processed in 0.129378 second(s), 18 queries .
