this had to hurt big time..
发表于 2021-9-1 23:18:09 | 显示全部楼层 |阅读模式
https://www.foxnews.com/us/michigan-...-sulfuric-acid
Reply:We made sulphuric acid and OLEUM from the off gasses in the copper smelter where I worked, just the gasses were enough to drop you at times.IMPEACH BIDEN!NRA LIFE MEMBERUNITWELD 175 AMP 3 IN1 DCMIDSTATES 300 AMP AC MACHINEGOD HELP AMERICA!“Freedom is never more than one generation away from extinction.We didn’t pass it to our children in the bloodstream".RONALD REAGAN
Reply:how do you fall into a vat of acid? that is the things nightmares are made of, his poor family.Do not argue with an idiot. He will drag you down to his level and beat you with experience.
Reply:Prayers for the man's family. I once had to change a bad battery in an Alco locomotive, it had swelled badly and was at the point of rupture when we started to pull it out of the tray. Oh, this thing was about 300 pounds too. On the way out it split and doused me with acid. The guys got me with a firehose immediately and helped tear off my coveralls and clothing and more fire hose. Luckily my underwear wasn't soaked with acid
Got some good skin burns on my lower legs though and totally ruined a good pair of Whites logger boots.
Reply:12V71
Originally Posted by 12V71
I once had to change a bad battery in an Alco locomotive . . . this thing was about 300 pounds On the way out it split and doused me with acid . . .  and totally ruined a good pair of Whites . . .
Originally Posted by OPUS FERRO
12V71Actually: 405 lbs. - I have pulled dozens/half from 'pocket-height' - Sorry about the Whites . . .HobbytimeSulfuric Acid - Sherlock Holmes . . . oil of vitriol . . . vitriolic speech . . . I recommend: you, and your cadre of 'Whipping Boys' - from the Political Thread . . .Gargle oil of vitriol - it would 'excoriate your vocal cords' - and terminate your diarrheic pronouncements . . .Sherlock channeled - 'you would type less - and think more' . . .Opus
Reply:Poor guy!
Reply:I worked with a guy that spilled battery acid on his pants. He went and washed them off and didn't have any others so he wore them the rest of the day. When he stopped by the convenient store on his way home. He reached in his pocket for change and the whole front of his pants came off in his hand. The threads they used for sewing  it with were not acid resistant like the material in the pants was. He could tell some good stories. One day on the way home a large German Shepard came and attacked his front tire, biting it hard enough to cause it to go flat immediately. He didn't change it until he had driven a mile from there on a flat.
Reply:Que the OSHA investigation.......When i grow up i want to be a welderPRIMEWELD TIG225ACDCPMillermatic 215Everlast PowerPlasma 50oxy/acNot enough talent to use any of it very well
GMT+8, 2025-12-20 18:33 , Processed in 0.130774 second(s), 18 queries .
