Respirator?
发表于 2021-9-1 23:18:08 | 显示全部楼层 |阅读模式
I'm looking for a respirator that will fit under my hood without the cost involved in a PAPR system. I can't really justify the cost for the amount of welding that I do. The copper company I worked for supplied a 3M respirator that had hoses that went over the shoulders with the filters in the back, but I can't seem to find them. I've tried the woven masks but they leak and fog up the lens cuz they don't seal, nor do they protect against anything but particulates.IMPEACH BIDEN!NRA LIFE MEMBERUNITWELD 175 AMP 3 IN1 DCMIDSTATES 300 AMP AC MACHINEGOD HELP AMERICA!“Freedom is never more than one generation away from extinction.We didn’t pass it to our children in the bloodstream".RONALD REAGAN
Reply:I like the Miller respirator
Reply:I use one of these..it has the down draft exhalation port so your lens won't fog up. Use the pink pancake filters and it fits under the hood fine. https://www.amazon.com/3M-Profession.../dp/B004HXBCMGMiller Multimatic 255
Reply:Thanks Louie, that looks like it might work, I have a facepiece that is similar. Here's a little story for y'all from my copper days. I was called out one night to balance a large blower that moved fresh air through the boiler to cool it quickly when they had a boiler leak, I know, I know all the company cared about was production, it was an Ahlstrom boiler and was notorious for leaking. Anyway, to continue, I loaded up the tools and my fullface respirator, which should have been sufficient, guess again, for some reason , while I had my head poked in the manhole hanging a trial weight the duct picked up a backdraft of concentrated SO2 gas and whatever in the heck else, but it was friendly to the filters, it came through the filters like they weren't even there, I pulled my head out , puking, eyes watering and my entire respiratory tract on fire! It turned out that the control room operators had done something that wasn't allowed at ANY time, it prompted some major changes in operation protocols. The balancing job was postponed to the next day and I think it also became a job that required a positive pressure(air fed) respirator which opens up a whole new set of circumstances.IMPEACH BIDEN!NRA LIFE MEMBERUNITWELD 175 AMP 3 IN1 DCMIDSTATES 300 AMP AC MACHINEGOD HELP AMERICA!“Freedom is never more than one generation away from extinction.We didn’t pass it to our children in the bloodstream".RONALD REAGAN
Reply:I use the same 3M half mask and recently switched to the Miller half mask. HEPA filters. No fogging of helmet, just sucks that you need to be clean shaven to use it. I always like to have a short 5 day beard, my baby face gets all torn up shaving every day.
Sent from my LM-Q710.FG using Tapatalk
RyanMiller Multimatic 200 tig/spool gun/wireless remoteMillermatic 350P, Bernard/XR Python gunsMiller Dynasty 350, Coolmate 3.5 & wireless remoteCK WF1 TIG wire feederMiller Spectrum 375 XtremeOptrel e684Miller Digital EliteMiller Weld-Mask
Reply:I've a bunch but you guys know I'm lotsa outside. I run this with a modded intake to accept 3m spig filters.
Reply:I've been using these for flux core or aluminium MIG welding:1E2400 5 Arco P2 Valved Cupped Welding Respiratorshttps://www.arco.co.uk/products/1E2400?s=1they're disposable, low profile, relatively comfortable and crucially they have an activated carbon layer to filter out nasty fumes. The valve points down which i think helps keep the hood screen from misting up.if I was welding every day, I would have a PAPR hood system for definite. They aren't that expensive in the long run.Last edited by Munkul; 02-25-2019 at 08:22 AM.
Reply:I'm going to purchase the the Respo Rator. I have facial hair and do not get a good seal. Thanks man never seen one before.Dave ReberWadsworth Ohio
Reply:Pretty unique apparatus. I don't think I'd care to put nose plugs on and have a breathing tube stuck in my mouth for any length of time but that's just me.
GMT+8, 2025-12-20 18:25 , Processed in 0.193291 second(s), 18 queries .
