Miller syncrowave 250
发表于 2021-9-1 23:17:49 | 显示全部楼层 |阅读模式
Having trouble with ac/hf side no control with foot pedal. I can turn the heat all the way down and it will burn a hole in 1/8 aluminum. Works fine on dc- with foot control. Works fine on dc+ . Any ideas
Reply:If you can post the serial number it will help the experts find the correct wiring diagram for your machine.Check out my bench vise website:  http://mivise.comMiller Syncrowave 250DXMillermatic 350P with XR AlumaProMiller Regency 200 with 22A feeder and Spoolmatic 3Hobart Champion EliteEverlast PowerTig 210EXT
GMT+8, 2025-12-19 16:09 , Processed in 0.093306 second(s), 18 queries .
