Can Alloy Silver be welded to Stainless Steel?
发表于 2021-9-1 23:17:46 | 显示全部楼层 |阅读模式
Can I weld Alloy Silver to Stainless Steel? If so, do you have any recommendations on how to accomplish this? Thanks!
Reply:You should be able to silver solder it. I don't think you could fusion weld it. I'm not sure the correct silver solder but you could call someone like Lucas Milhaupt who are the leaders in silver solder. I included a list of the most common silver solders from their site.https://lucasmilhaupt.com/EN/Products.htmhttps://lucasmilhaupt.com/Lucas/Down...TradeNames.pdfLast edited by Welder Dave; 06-30-2021 at 02:53 PM.
Reply:Yes no problem. Silver solder will braze silver to stainless no problem. How much strength you need determines the silver content needed in the solder.
Reply:This is perfect. Thank you so much.
Reply:If you do not need ultimate strength the low temperature silver solder is best. Requires way less heat input and has some decent strength.The little stay brite silver solder kits work very well for small jobs.https://www.ebay.com/itm/25263160846...IAAOSwcUBYJdy9
GMT+8, 2025-12-19 16:10 , Processed in 0.093297 second(s), 18 queries .
