Looking for a funnel for filling Concrete bollards
发表于 2021-9-1 23:17:44 | 显示全部楼层 |阅读模式
I do bollards enough to want to get a funnel for filling 4" and 6" bollards.I was thinking a 12x4 pvc reducer and 12x6 but not at $140 each and none second hand from eBay. Anyone have another funnel idea that isn't just making one.Sent from my 2PS64 using Tapatalk
Reply:And we are currently using old traffic cones since we can break the concrete after it hardens without damaging the cone.Sent from my 2PS64 using Tapatalk
Reply:a plastic water cooler jug with the bottom sliced off might work.i.u.o.e. # 15queens, ny and sunny fla
Reply:That's what the pump truck is for!!!!!!
  Have also used the big traffic cones.  What about rolling up a piece of FRP with a couple of 1/4-20's and fender washers to hold it in shape you want??I've got a big plastic funnel for filling 8" pipe.  I'll have to see if I can dig it up.
"You can't out puke a buzzard"
Reply:Put a few gallons of water in the pipe then just pour in dry concrete from the bag until all the water flows out, then just finish of the top.***********************CR
Reply:A tremie funnel is what I'm talking about. But probably cost a couple hundo.
Reply:Traffic cone... you can't improve on perfection
Reply:Go to lumber yard or local building supply, ask for a footing bell for a sonotube,  don't know where you are but in the North east these are common in frost areas. Designed to be buried  with the sonotube on top, makes for a footing that is wider than the sonotube, But instead of digging with a post hole digger and just dropping the tube in you have to excavate a lot more. Anyway it should make a great sonotube concrete funnel.  About $20https://bigfootsystems.com/include/products.htm
Last edited by kolot; 08-21-2018 at 02:10 PM."Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251   Syncrowave 300   30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200   1 short hood    SA250    SAM 400
Reply:Galvanized chimney flue pipe,   6x4 reducer, put a 8x6 in that  but has to be cleaned right after use."Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251   Syncrowave 300   30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200   1 short hood    SA250    SAM 400
Reply:Or just serch for "cone template calculator".....LanceMultimatic 255 w/MDX-250 EZ-Select gunHypertherm Powermax45 XPHeck Bevel Mill 4000Miller/Smith heavy duty torch set9" Evolution circular saw
Reply:I will have to second the traffic cone. That's how we filled all the terrorist stops at penn station. Hundred million dollar job hahaSent from my SM-G930V using Tapatalk
Reply:I use old road cones. The plastic ones work best. The rubber ones move too much. Has worked out great for years Sent from my SM-G960U using Tapatalk
Reply:Found this on Amazon under concrete funnel
GMT+8, 2025-12-19 16:11 , Processed in 0.091120 second(s), 18 queries .
