Finger control torch switch
发表于 2021-9-1 23:17:31 | 显示全部楼层 |阅读模式
Lugweld Will one of the Everlast finger controls work on a 2018 Alpha 201 Tig .The plug is a seven pin.When I went to your sight it showed a couple of Variations.Thanks Tony
Reply:I am not sure.  They are designed to work with the Everlast Digital products.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
GMT+8, 2025-12-20 14:40 , Processed in 0.090161 second(s), 18 queries .
