Looking for Mig torch cover
发表于 2021-9-1 23:17:29 | 显示全部楼层 |阅读模式
Been searching for a 15th MIG torch cover for my new Tweco 250A torch. Everything is for the 12ft TIG torches.  Any economical suggestions?  ThanksSelf-sufficient...to the end...Engineer and build it allMiller CST280ESAB EMP 235AbeneRockwellAtlasFlukeand the list goes on....
Reply:Wow!!! you go through a lot of covers!!!! not sure where to get better ones...Oh.... I see you meant 15 foot..
Reply:I buy the 12ft ones because the only usable coverage is really 12ft anyway, you don't run them all the way to the backend or to the mig gun, just space them in the middle of the cable hose. Anchor sells some good economical mig covers, I think the name changed to Best Weld made by Weldas Pythonrap.ESAB Rebels 215 and 235, ESAB HELIARC 281i, ESAB ET 301i, Hypertherm 85 and 45XP, Thermal Arc 185, TD 60i, HTP PRO PULSE 300
GMT+8, 2025-12-20 14:39 , Processed in 0.124056 second(s), 18 queries .
