252i error 14
发表于 2021-9-1 23:17:29 | 显示全部楼层 |阅读模式
I purchased the ESAB 252i last year. It's been pretty much problem free until this past Friday. It stick welds fine but Error 14 pops up on the screen in both mig and tig mode and neither of them work. I was curious if anyone has had this same error and what did it take to fix it... parts and money? Thanks
Reply:Get the manual from the ESAB site, it will be in there, I don't recall what that code is.ESAB Rebels 215 and 235, ESAB HELIARC 281i, ESAB ET 301i, Hypertherm 85 and 45XP, Thermal Arc 185, TD 60i, HTP PRO PULSE 300
Reply:From  the service  manual  ESAB FABRICATOR 252iTROUBLESHOOTING 6-2 Manual 0-545114 Trigger Fault Fault occurred detectingtrigger state/conditionA. Trigger may be already actived when MIG process mode is selected- verify that trigger is not accidentally activatedB. Trigger may be faulty and/or dirty, test and replace MIG Torch/triggerdevice. If this does not fix the problem change Main Power PCB.
Reply:I have the manual.  It talks about the trigger yes.  I've checked it out, trigger is working fine.  Didn't have any more time to mess with it.  Had dealer pick it up.  Should know something soon.Thanks
Reply:Update... welding shop said they couldn't find anything wrong with it.  Ran fine.  Brought it back and tried it.  Welds fine for now.  Just a fluke I guess.Last edited by Monster77; 03-19-2019 at 10:45 AM.Reason: Forgot something
Reply:Keep those fingers crossed.Thermal Arc 320SP ( Lorch )Cobra PythonsThermal Arc 300 AC/DC  ( Sanrex )ESAB 301i AC/DC  ( Lorch )Thermal Arc 161STL  ( WTL )Thermal Arc 190S  ( Sanrex )Cut Master 82, 42. Cut45 ( WTL )Victor Gas Apps.Boxes and boxes of welding crap.
GMT+8, 2025-12-20 14:38 , Processed in 0.091660 second(s), 18 queries .
