ESAB 4000i vs 4004i
发表于 2021-9-1 23:17:28 | 显示全部楼层 |阅读模式
HiI am trying to decide on buying either an ESAB 4000i or 4004i for robotic applicationMy welding requirement is for carbon steel only with thicknesses ranging from 0.5 mm to 2 mm.Do I need the 4004i which is the newer version and of course the more expensive ?Thanks
Reply:Curious of Why ESAB? I'd suggets many before ESAB but I could be missing something. Good luck in your search.Thermal Arc 320SP ( Lorch )Cobra PythonsThermal Arc 300 AC/DC  ( Sanrex )ESAB 301i AC/DC  ( Lorch )Thermal Arc 161STL  ( WTL )Thermal Arc 190S  ( Sanrex )Cut Master 82, 42. Cut45 ( WTL )Victor Gas Apps.Boxes and boxes of welding crap.
GMT+8, 2025-12-20 14:37 , Processed in 0.070427 second(s), 18 queries .
