Century Monkey be Wards AC DC repair
发表于 2021-9-1 23:17:20 | 显示全部楼层 |阅读模式
I need to make it work. It is completely dead. Has power in past the switch, but nothing out. No humming, no fan.
Reply:What did it do when it died?Died while welding or worked one day, dead the next?Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:I bought it as working, it's not.
Reply:Did you check to make sure you have 240? What instrument are you using to determine voltage? Sounds like maybe you only have 120. Check leg to leg at the outlet and again inside the machine. If you have 120 between hot and ground but zero between hot and hot you are hooked up wrong.Miller Challenger 172Miller Thunderbolt AC/DC 225/150Miller Maxstar 150 STLVictor 100CVictor JourneymanOxweld OAHarris O/ASmith O/A little torchNo, that's not my car.
Reply:120 on each hot wire.I'll double check the ground.Don't think that's it though.Checked with a multi meter.
Reply:Finally some good news.Turns out my outdated circuit breaker box doesn't connect to the two busbars at every two stations. I had to take it loose and wiggle the busbars to figure out that of the six stations, only the inner for would work for 220.  Welder makes that happy humming noise now.
Reply:I appreciate all your help. It's just good to get it going.
GMT+8, 2025-12-20 14:43 , Processed in 0.107769 second(s), 18 queries .
