question for Jim Colt
发表于 2021-9-1 23:17:15 | 显示全部楼层 |阅读模式
I have a powermax 1250 that is about 15-17 years old but with very little use and have discovered the retaining cap has to be loosened about a turn and retightend every time to use the torch or the machine faults. What is going on? T80 torch.
Reply:Safety feature so that you can't fire the torch with the consumables off or loose. If you take the front end parts off you can see the sensor. May even be the cap.
Reply:Yeah I had the whole torch head apart thinking I was chasing a broken wire then discovered I have to loosen the retainer cap about a turn and re tighten every time to get it to fire off.
Reply:I also discovered this morning if the trigger is teased enough times it will eventually light off with out loosening and re tightening retaining cap.
Reply:When the cap is overly tightened it can crush the swirl ring (which controls gas flow and is a slide bearing for the blowback electrode), impeding the movement of the electrode. First...you may want to replace the swirl ring, and make a habit of just snugging the cap until you feel some slight resistance.  Jim Colt   Hypertherm
Reply:Thanks Jim. All working fine now. Are all the parts still available for the T-80? Looking around on the internet for parts I see sellers are saying that torch is obsolete.
Reply:Consumables and torch repair parts are still available. The torch assembly is not....as it has been replaced by the Duramax torch...same price, longer consumable life, better cut quality and better long term reliability.   Jim Colt
GMT+8, 2025-12-20 20:30 , Processed in 0.105645 second(s), 18 queries .
