Wiring a remote switch on a pt 40 plasma torch
发表于 2021-9-1 23:17:11 | 显示全部楼层 |阅读模式
Looking for help/ advice about wiring a remote switch for my pt 40 torch. I mostly use my plasma cutter on a homemade (old drafting machine mechanism) plasma cutting guide. Currently I use a mechanical device to pull the trigger....I was thinking a remote switch might be better. Any insights?
Reply:Its a simple operation. Take the cover off unplug the switch wires from J13 and J14. Then plug your wires in to J13 and J14 from your switch, push switch torch turns on, let off switch torch will go off.
www.georgesplasmacuttershop.comPlasma Cutter and Welder Sales and Repairs--Ebay storeTec.Mo. Dealer Consumables for the PT and IPT torch's
Reply:Is that 120 volts? Push button best? Thanks for your input!
Reply:There is no voltage there, any push button switch will work.www.georgesplasmacuttershop.comPlasma Cutter and Welder Sales and Repairs--Ebay storeTec.Mo. Dealer Consumables for the PT and IPT torch's
GMT+8, 2025-12-20 20:42 , Processed in 0.145202 second(s), 18 queries .
