I recently purchased a display unit protig from the local HF. The only thing included with the welder was the torch, I have since purchased a pedal separately. I have been able to find regulator, ground, stinger, and lens kit but having trouble finding both the 240V AC and 120V AC power cables as well as adapter. Anyone know where I might find some links to those? I have spent about 30 minutes searching and haven't been able to turn anything up.
Reply:Just open it up and install your own power cable.www.georgesplasmacuttershop.comPlasma Cutter and Welder Sales and Repairs--Ebay storeTec.Mo. Dealer Consumables for the PT and IPT torch's
Reply:Don't open it up, the twist lock connector is standard and can be had at home Depot. Buy the hardware and make your own cables. If that isn't good for you, order the plug from Lincoln. They use the exact same twist lock configuration.Miller Multimatic 255
Reply:I am 99% sure this is the one https://www.homedepot.com/p/Legrand-...CCV3/202039718Miller Multimatic 255
Reply:It's just a standard twistlock connector. You can pick up the parts to make your own cord at your local big box store.If you look inside the power connector you will see a number something like L6-30P(P stands for plug).The mate to this will be the same number except it will have an R at the end(R stands for receptacle).Buy bulk cord to match the current rating of the receptacle for the machine in whatever length you need(within reason).Buy the plug that matches the outlet that will be powering the machineThe black and white wires go on the X and Y terminals(doesn't matter which just keep them the same at both ends) and green goes on G.Plug it in and get to welding!
Reply:For anyone who may run into this issue in the future, the correct plug for the protig 200 is this onehttps://www.homedepot.com/p/Legrand-...CCV3/100137115 |
