Harbor Freight wheel jack
发表于 2021-9-1 23:17:08 | 显示全部楼层 |阅读模式
Going to get one to try it out for putting those heavy truck wheels and tires on. Will use my Labor Day 25% off coupon and hopefully they don't consider it a floor jack as the coupon doesn't work on floor jacks. Anyone use this, or the slightly bigger Daytona one?Miller Challenger 172Miller Thunderbolt AC/DC 225/150Miller Maxstar 150 STLVictor 100CVictor JourneymanOxweld OAHarris O/ASmith O/A little torchNo, that's not my car.
Reply:That goes under the tire and only jacks up a little bit to get the tire off the ground so you can push the vehicle in a corner or something. So how are you going to use that to put tires on?Oh ok just thougt about it. You're going to use another jack to raise the vehicle and use that jack to position the tire to the lugs. Back where I come from we use a pry bar about this  long which is alot cheaper than $99. Do you change tires that much you need one of those?Last edited by jfh; 08-31-2019 at 10:36 PM.
Reply:I used a floor jack to handle the tires/wheels for the ambulances, we ran an all steel belted tire & they  weighed almost 60 lbs without the wheels & they were steel, it didn't take me long to figure out that I didn't want to make a career of manhandling those things. Wheels came off every service for balance & rotate, service was done every 3000 & I've seen them do that in a 3 day shift.Last edited by CAVEMANN; 08-31-2019 at 10:52 PM.IMPEACH BIDEN!NRA LIFE MEMBERUNITWELD 175 AMP 3 IN1 DCMIDSTATES 300 AMP AC MACHINEGOD HELP AMERICA!“Freedom is never more than one generation away from extinction.We didn’t pass it to our children in the bloodstream".RONALD REAGAN
Reply:I haven't tried this jack version but we did buy a bunch of the HF wheel dollies. They're all too flimsy to hold a decent sized America car and they all collapsed. Some didn't collapse until we tried the move the car but others collapsed as soon as we put weight on them.  That's pretty much what I found with most things from HF, it's all too small or too weak to be useful.
Reply:We had a dolly type device at the shop for putting  wheels on and taking them off trucks. I never sawit used.I think it wound up getting thrown away.Guys just use a pry bar.Miller a/c-d/c Thunderbolt XLMillermatic 180 Purox O/ASmith Littletorch O/AHobart Champion Elite
Reply:Prybar or a large starwrench
Reply:I haven't used that one, but have used them before for their intended purpose.  They work pretty well, just gotta push on a solid spot (no denting) to get moving.  So I think they'd be no problem for tires/wheels - no sheet metal to bend and plenty of places to grab.  At most it might be a slight nuisance getting the lugs to line up spot on vertically.  But you might find that enough reason to pass on them.Last edited by Weldalittle; 09-01-2019 at 07:48 PM.
Reply:Did not buy it, I didn't really understand how they worked, by pinching in on the wheel and only raising it slightly off the ground. I can see where they would be useful as intended with four, on very light vehicles, but to raise a tire into position not so much. When I work on my Superduty or my 3500 doing brakes etc those heavy wheels always get me. I think I will fab up a cradle to fit the small floor jack. I have used a bar but it doesn't work real good when you lift the vehicle a foot or so. It will only get worse as I get older.Miller Challenger 172Miller Thunderbolt AC/DC 225/150Miller Maxstar 150 STLVictor 100CVictor JourneymanOxweld OAHarris O/ASmith O/A little torchNo, that's not my car.
Originally Posted by Sandy
I wonder if those black tube looking things actually roll ? If so that part could be handy for rotating the tire to position the holes and bolts easier.
Reply:There's at least twenty different brands(mostly chinese) of wheel dollies out there that could easily be copied by the average welder
Reply:I would also go with a wheel dolly, or atv/transmission jack or hydraulic lift table depending on how heavy the tire is.  Can't beat the wheel dolly though for convenience and speed unless they are REALLY heavy tires.  Those wheel dollys are great though for moving your car or equipment with big enough tires around tight spaces.
Reply:I was thinking the HF motorcycle lift that looks like a small duct jack would work nicely with a bit of modification.
Reply:Ronsii has a good idea. Thinking about those types of things, I have taken the round part (the part that contacts the vehicle) off my jack before and inserted a self fabricated gas tank holder into the hole to raise and lower gas tanks with my jack. You may be able to make something with 2 forks that will bolt down in the jack hole without having to buy a bunch of stuff. If you do it that way, it is made in the USA.
Reply:I always said I was going to fab a piece to go in the hole for the lift saddle with 2 rollers so you didn't have to try to get the tire/wheel on the jack with the lug holes in the right place.IMPEACH BIDEN!NRA LIFE MEMBERUNITWELD 175 AMP 3 IN1 DCMIDSTATES 300 AMP AC MACHINEGOD HELP AMERICA!“Freedom is never more than one generation away from extinction.We didn’t pass it to our children in the bloodstream".RONALD REAGAN
Reply:How about fabricating a fork, something like a set of forklift forks, that replaces the arm extension for a HF shop crane - cherrypicker? (And use the crane at a right angle to the vehicle).This would give height adjustment, and considerable height, as well as allowing you to carry the tire out of the way.HF MIG-180 with all the mods.Grizzly H8153 Stick/Tig Pulse 130/160.Wards PowrKraft AC-230. Stick & carbon arc.
Reply:I think this is more what you are looking for instead of re-working a shop crane.https://www.harborfreight.com/high-p...ift-99887.htmlPaul
Reply:I don't know about you guys but most of the tire work I do ends up being outdoors on very uneven ground and usually not ideal conditions for any kind of small wheeled device with a load to roll.... and the few jobs I do indoors on a flat pad would not have enough room for a shop crane and attachment to come at it from the side... there's only two reasons I can think of that I don't have one of the wheel dollies I picced earlier in the thread... 1.I am too cheap to buy something that easy to make and 2.I just haven't gotten aggravated enough lifting tires with a bar/star to force myself to build a dolly just for that purpose
Reply:I use the same floor jack I use to lift my truck to lift the tires into position when I'm ready to remount one. I get the truck up and on a jack stand to remove the tire. Then, when it's time to remount the tire I roll it onto the floor jack and line it up with the lug nuts. Works perfect. They're cheap enough that you could have one dedicated to tire duty.
GMT+8, 2025-12-20 20:19 , Processed in 0.093696 second(s), 18 queries .
