Lincoln square wave tig 300 wire feeder?
发表于 2021-9-1 23:17:01 | 显示全部楼层 |阅读模式
Hi guys!Curious if it's possible to add an wire feeder for mig welding to my square wave tig 300?If it is what wire feeder would you guys recommend?
Reply:Readywelder.com  I have hooked one up to a stick welder.
Originally Posted by Chipped tooth
Hi guys!Curious if it's possible to add a wire feeder for mig welding to my square wave tig 300?
Reply:Thanks tapwelder I'll check it out.I don't plan on using it to weld aluminum.I use tig feature for that.I just need a bigger mig for some equipment repairs.I used a miller 250 syncrowave that had an feeder attached to it and it worked really well but that was probably 10 years ago now.
GMT+8, 2025-12-20 20:28 , Processed in 0.095175 second(s), 18 queries .
