Can I convert/ use Lincoln Ranger 8 K1616 on my house Propane? It has Vaporizer-Regulator P/N: 11A17-001 S/N: 000802Nikki WP250 PSI 668078. It runs, but at very low idle. Do I need to tap into the high side of the residential tank?
Reply:Need to pull off the liquid valve. The job of the vaporizer is to vaporize the liquid LPG. The regulator reduces and controls the pressure to the fuel mixer (referred to by some as a carburetor).MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110
Save Second Base!
