80's lincoln idealarc 250 weight?
发表于 2021-9-1 23:16:59 | 显示全部楼层 |阅读模式
I know this machine is heavy , but is it possible for 2 guys to pick it up and put in the back of my truck?  There is one I'm buying a few hours away and they have no way to get it in my truck , said its all up to me.  So can 2 guys pick one of these old roundtops up ? Thanks-art
Reply:rent a refrig/stove/washer dolly will make it easy to loadidealarc 250/250 ac-dc tigidealarc 250/250 ac-dc tig #2 used for sticklincoln sp100hh125dual arbor grinder polisher30 yrs of hand tools52 pitch blocks 6p-26prake gauge -pitch gaugeG&D prop repair 918-207-6938Hulbert,okla 74441
Reply:A quick search I found aroud 350lbs. I could set that thing on the tailgate myself.
Reply:I've managed to load some pretty heavy tools myself using a couple boards or ramps and sliding the object up rather than lifting. Thats often how I load my genset, plate compactor wheelbarrow compressor and other heavy awkward items. An engine hoist and some straps also works if you have access to one.I guess it all depends on the 2 guys. I worked one year with a guy who played on the practice squad for a pro football team. I'd bet he could load it himself if he could get a decent grip on it.
.No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:350 lbsIf yours has an eye hook on it like mine does, I use a chain lift to lift the unit in the air, then back my truck under it and set it down.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:I load mine by myself exactly like DSW described
Reply:Thinktwicez71,Yesterday I had a chance to give an older TM 400 "round top" a quick test lift. Although the welder was heavy, it was not awkward. I was able to easily tip it up to balance on its back edge, and then "walk" it, by myself. The weight's center seemed high enough that the welder could be tipped into a pickup without much trouble. If necessary, I believe that a 210# weakling, such as myself, could load the welder alone. I'm sure two guys will be able to load your welder, no problem.Good LuckLast edited by denrep; 11-12-2010 at 10:11 AM.
Reply:Scored my first idealarc 250 roundtop tonight , in great shape.  7056-c is the code so it has the capacitors , drove 4 hours to get it , but I wanted it bad lol.  Paid 125.00 , I think I did good,  what is there for maintenance on this , how do I grease or lube the polarity switch and crank ? Any tips appreciated, thanks
Reply:Not much for maintainence on these units.Remove the cover and blow out the dust. Thats all I do to mine.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:well i got the 50 amp dedicated line installed the other day , and i welded my first beads with it yesterday with some 6013 , i couldn't help but giggle and have a **** eatting grin on my face the whole time i was welding.   we have about 15 miller xmt 304's at the union hall that i take my welding classes at and i would have to say this machine has a nicer arc and is much easier to get the rod started.  i love it
"I'd Rather die on my feet , than live on my knee's"64' Lincoln Sa 200 Redface Code 5496 - Sold 72' Lincoln Idealarc 250 (Roundtop)
MillerMatic Vintage
Reply:Welcome to the "dark side" err....I mean red side.......Congrats on the pickup as you got a great deal.......1981 Lincoln SA 200Miller Trailblazer 302gMiller 211 Mig Welder w/ AutosetI'm learning to stick metal together
Reply:......Last edited by wrecmom; 09-17-2011 at 12:28 AM.Reason: It needs to be deleted, as I have rewritten it. I had accidently quoted the wrong person.
Reply:.....Last edited by wrecmom; 09-17-2011 at 12:41 AM.Reason: .....
Reply:Just picked my roundtop idealarc 250. Has an eye hook on top.  Funny thing the front nameplate has no info filled in for, phase, amps, model number or code number.  For a s/n all thats there Is AC-    This is an AC DC machine with the switch.  Anyone have any ideas why no name plate info is on it?
Reply:JohnYour machine has a replacement faceplate.  All transformer Lincolns start with AC as part of the serial number. By looking at the insulators around the output lugs you can roughly determine before or after around 1980. If the have 2 little bumps where screws thread in from the back it’s the newer machine. Sometimes the serial number is written on the bulkhead panel above the fanSent from my iPhone using TapatalkSteveMiller Dialarc 250 (1990)Miller Maxstar 140 STR (2003)Lincoln SA200 Redface Pipeliner (1966)Lincoln MP210 (2015)Victor and MECO torches
Reply:Thanks Steve. I did a live chat with Lincoln Electric, they basically said the same as you.  I’ll be going through the whole machine to clean it up, including opening it up to clean and ensure the fan is working. Hopefully there’ll be some info inside.  Appreciate the tip about the lug bumps, Lincoln Electric didn’t mention that.Johng34
Reply:Send me a PM if you need any help. Sent from my iPhone using TapatalkSteveMiller Dialarc 250 (1990)Miller Maxstar 140 STR (2003)Lincoln SA200 Redface Pipeliner (1966)Lincoln MP210 (2015)Victor and MECO torches
GMT+8, 2025-12-20 20:27 , Processed in 0.314917 second(s), 18 queries .
