Miller Trailblazer 250G short problem
发表于 2021-9-1 23:16:54 | 显示全部楼层 |阅读模式
Help!! I was doing some cleaning on my Trailblazer 250G and noticed some soot on the inside of the cover and when I looked at the machine, much to my dismay, I discovered the cause: apparently the insulation has been rubbing on the cover, and one of the wires shorted out, and burned through. Obviously I will have to either fix this myself, or have this repaired. Has anyone ever had this happen on their machine? Can I splice in a new piece of wire? Can it be soldered? Or should a mechanical splice (such as using a split bolt) be used? Also what can I use to re-insulate the wire? You can see on the right hand side of the picture, that that wire insulation is also wearing through from rubbing on the cover.
Sent from my iPhone using Tapatalk
Reply:If it were mine I'd clean off any insulation coating and use a mechanical crimp splice using the existing piece of lead.  I'd "patch" the damaged insulation with a piece of heatshrink tube and wrap the entire bundle with plastic wire loom.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110
Save Second Base!
Originally Posted by ironwrx
Thanks for the input. I thought about using heat-shrink, but wondered  if the wires would possibly heat up in use, and if the tubing could handle the temperature? I mean, why would the original insulation be fiberglass not plastic? Also what about high voltage rubber tape?Sent from my iPhone using Tapatalk
Reply:This possibly, don't see it in red.High-Temperature Electrical-Insulating Tube Sleevinghttps://www.mcmaster.com/standard-ca...tube-sleeving/
or   https://www.newark.com/c/cable-wire-...leeving-tubing
Last edited by albrightree; 04-04-2021 at 12:48 PM.Airco 250 ac/dc Heliwelder Square waveMiller Synchrowave 180 sdMiller Econo Twin HFLincoln 210 MPDayton 225 ac/dcVictor torchesSnap-On YA-212Lotos Cut60D
That looks perfect for insulation, but how shall I reconnect the wires? I think crimp sleeves are mainly for stranded, not for solid wire. Sent from my iPhone using Tapatalk
Originally Posted by SweetMK
Get it big enough to slide over the crimped on end,,,
Reply:I suppose it depends on how good of a crimper you have.
GMT+8, 2025-12-20 20:39 , Processed in 0.134517 second(s), 18 queries .
