Looking for Bodine nsh-13d3 gear motor replacement
发表于 2021-9-1 23:16:45 | 显示全部楼层 |阅读模式
Need to replace a Bodine nsh-13d3 used to feed wire in Millermatic 200.Having trouble finding used source or replacement alternative.  Does anyone have one to sell?
Reply:This website lists repair or purchase options from $170https://www.radwell.com/en-US/Buy/BO...TRIC/NSH-13D3/You may have better luck searching for the miller part number for the whole drive unit.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:The Bodine motor most can replace the brush odd you turn the commutator.Both are simple to do. The Bodine motors are built last I like pick the old Bodine motors and rebuilding for my own projects.If you just want to new motor post a photo of name plate and shaft size and I see find replacement at good price. Dave
GMT+8, 2025-12-20 21:45 , Processed in 0.115651 second(s), 18 queries .
