Torch & Plumbing Hardware
发表于 2021-9-1 23:16:45 | 显示全部楼层 |阅读模式
Hey Folks, been a while since I last visited WW, hope everybody is well and healthy.Set up my glass blowing shop and slightly over ordered a few things and thought I'd offer it to you all.When inquiring about a specific item(s), please use the numerical number identifier along with a brief description of the item to ensure accuracy of ordering/purchasing.Items are brand new and unused unless otherwise disclosed.Priced as listed plus shipping.Accepting payments via PayPal.Local pick up in Sarasota, FL.Apparently WW doesn't like my draft format and the listing has turned into scrambled eggs.The numerical number right before the listed price is the quantity available. If still in question just refer to the pics.Thanks for looking.ITEM(S)               Qnty        PRICE1) Flashback Arresters                 3$30 ea.2) Flashback Arresters                 2$25 ea.3) Fuel line hose nuts – 9/16-18 LH               28$1.25 ea.4) Oxy line hose nuts – 9/16-18 RH               28$1.25 ea.5) Hose Barbs – ¼” ID               60$1.25 ea.6) Hose Ferrules (.562”) – for ¼” ID hose       50$1.25 ea. 7) Fuel Adapter Bushing – ¼ NPT to 9/16-18 LH       12$2.00 ea.8) Oxy Adapter Bushing – ¼” to 9/19-18 RH       12$2.00 ea.9) Torch Tips – Knight 1081A – Diverted Fishtail         6$20 ea. / 3 for $50.10) Manifolds, aluminum –                          2$25 & $301 Had a misaligned NPT port from the start. It’s been re-tapped. Anodizing finish started to come off during Ultrasonic O2 cleaning.1 is priced at $30 and the one with a re-tapped port is $25.11) ½” 304 SS Needle Valves, 1000 WOG, Teflon seals.         3$30 ea.12) ½” NPT Full Port Ball Valves, 316 SS, 1000 WOG         2$20 ea.13) TCI ¾” NPT Full Port Ball Valves, 316 SS, 2K WOG         1$35       O-ring seals.14) 175 psi Check Valve, ¼” NPT                 1$1015) 200 psi Check Valve, ¼” NPT (OPEN PACKAGE)         1$6.5016) ¼ In-line Check Valve (M X F)                 1$817) Air Pressure Gauge, 0-200 psi                  1$9       (not rated for concentrated O2).18) 1” SS Cylinder port plug, 304 SS, NPT         1$1019) Reducer Bushing, ¾” NPT to ¼” NPT, (M X F), 316 SS 1     $520) Reducer Bushing, 1” NPT to ½” NPT, (M X F), 316 SS 1$1021) Reducer Bushing, 1” NPT to ¼” NPT, (M X F), 316 SS 2$6 ea.22) 3/8” NPT TEE Unions, 304 SS, Class 150     2$5 ea.23) ½” SS Cylinder Port Plug, 304 SS, NPT          2$5.25 ea.24) ¼” SS Cylinder Port Plug, 304 SS, NPT         1$325) Reducer Bushing, ½” MNPT to 3/8”  FNPT, 304 SS 2$5 ea.26) NP Brass “Push to Connect” elbow, (pneumatic) 2$5.25 ea.       3/8” ID tube x ¼” NPT, 27) NP Brass “Push to Connect” Straight adapter,         2$3 ea.       3/8” ID tube x ¼” NPT28) SMC “Push to Connect” Straight adapter, 2$13.50 ea.       ¼” ID tube x ¼” MNPT, 316 SS29) Reducer Bushing, ¾” MNPT x ¼” FNPT, Brass 1$4.5030) Parker TEE Union #2203P6, 3/8” FNPT x 3, Brass 2$10 ea.31) Reducer Bushing, ½” MNPT x ¼” MNPT, Brass         2$2 ea.32) Nipples, ½” MNPT x 3”, Brass         2$5.50 ea.33) Fuel Valve Adapter for disposable cylinders (CGA600) 1$16       to“MC” Acetylene CGA 200 regulator.34) Fuel Valve Adapter for disposable cylinders (CGA600) 2$6 EA.       1”-20 x ¼” FNPT
Reply:Judging by the photo, the products look high-quality. Also, it’s worth paying attention to the fact that this guy has been a member of this forum for several years, so I think you can trust him! It’s a pity that I didn’t find this topic earlier, about two months ago, when I had plumbing problems. I had an issue with the full port ball valve three times, and each time the root of the problem was a poor-quality valve (this is weird, since each time I bought valves in different plumbing stores). As a result, I just got tired of it and decided to turn to https://sosplomberie.be/plombier-bruxelles-belgique-depannage-plomberie to fix the breakdown and, to be honest, this was the best decision in a long while. Well, I hope the reviews of this seller from his future customers will be nothing but positive, so I can finally find a vendor with high-quality plumbing products...Last edited by TouchForce; 04-05-2021 at 02:31 PM.
GMT+8, 2025-12-20 20:26 , Processed in 0.134203 second(s), 18 queries .
