Wanted spoolmatic 3
发表于 2021-9-1 23:16:44 | 显示全部楼层 |阅读模式
Looking for a spoolmatic 3 for my millermatic 200 and cables to for a wc1 to connect to my other Miller matic 200 for spoolmatic 1
Reply:Prior to the MM200 serial number JJ407380, the Spoolmatic 1 is a direct connect that doesn't require the WC1 weld control. Effective with serial number JJ407380 the WC1 is required to use the Spoolmatic 1 but the Spoolmatic 3 is a direct connect.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110
Save Second Base!
Reply:I couldn't tell you the serial numbers of the machines of hand right now but they both have 14 pin plugs on them
Reply:The 14-pin receptacles make the SM-3 a direct connect for both machines.  You could also use the current - and lighter - Spoolmatic 15A or 30A guns with the WC-24 with both machines.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110
Save Second Base!
Reply:Yeah I have thought about getting a 30a but I can't afford it for my shop.
GMT+8, 2025-12-20 20:21 , Processed in 0.088905 second(s), 18 queries .
