Looking For Info On Hobart Welder/Gen
发表于 2021-9-1 23:16:42 | 显示全部楼层 |阅读模式
Hello everyone, I have found myself needing a larger welder I have a 140 that I use for small MIG work but I would like a SMAW welder and in the local classifieds there is a self powered Hobart welder for cheap but Not running. I did a quick google search and came up with no real information on it so looking for some input from people more knowledgeable than myself.Model WZ-252 and I cant make out what kind of engine is on this unit. It looks to have a valve cover that says OMC just want to see if it would be worth gambling over. Thanks for any help!
Reply:I sent you a PM.Thermal Arc 320SP ( Lorch )Cobra PythonsThermal Arc 300 AC/DC  ( Sanrex )ESAB 301i AC/DC  ( Lorch )Thermal Arc 161STL  ( WTL )Thermal Arc 190S  ( Sanrex )Cut Master 82, 42. Cut45 ( WTL )Victor Gas Apps.Boxes and boxes of welding crap.
GMT+8, 2025-12-20 20:21 , Processed in 0.091397 second(s), 18 queries .
