Free range selector / rheostat for the Hobart GR303
发表于 2021-9-1 23:16:41 | 显示全部楼层 |阅读模式
This control panel is all I have left from a GR303 that I dismantled about 7 years ago.  I don't have the heart to throw it in the garbage, because there must be someone out there that is looking for a range selector.  I'm not saying that I know it works, but heck, its free.Just pay the shipping and its yours.Note:  I can't get the set screw loose so I cannot remove the range selector from the panel.  I may have to destroy the panel to get it out (or just send you the whole panel!).Thanks
Reply:I wonder if that's pretty close to the same range selector that I have on my Hobart g-213? If so I would interested in the fine control adjustment rheostat that's in the middle of the range selector
Reply:I think of you bust off the small knob in the middle,you'll fine 3 screws which hold the small alum dial in place,remove them and the dial will come loose,then there are 3 more screws and the large hand wheel will come loose and then you can remove the 3 screws on the outside of the housing and the range selector should come loose.
Reply:joestewart,I haven't heard from you,did you get rid of the range selector?
Reply:have you tried a PM to him?MikeOl' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:Sorry about that!  I haven't checked the thread in a few days.  Yes, I still have the range selector.  I'll have to bust off that little plastic knob in the center to get it all off though.  Let me know if you are interested.  PM me your mailing address.  Should fit in one of the "flat rate boxes" that the post office has......
Reply:I've sent you a PM with my address.thanks
Reply:a great big thanks to joestewart for sending me the Gr303 range selector.
GMT+8, 2025-12-20 20:26 , Processed in 0.096266 second(s), 18 queries .
