hobart titan 8 ac/dc weld gen
发表于 2021-9-1 23:16:41 | 显示全部楼层 |阅读模式
need info on starter soleniod titan 8 kohler 18 hp
Reply:hi what kind of info do you need. are you missing the solenoid or is it not working?i just bought one of these welders and it is missing a part that i need info on. mine is missing a piece right in front of the actual generator. might you be able to send me a pic of what the wires are hooked up to right before they go the out put for the welding leads?
GMT+8, 2025-12-20 19:59 , Processed in 0.142426 second(s), 18 queries .
