Where to buy solvent resistant orings
发表于 2021-9-1 23:16:36 | 显示全部楼层 |阅读模式
This valve is out of my AC flush bottle blow gun, it sticks real bad, won't return at all and I figure the oring must be swelled. Where do I get some good orings that will hold up to solvents? Not sure what to look for, Viton?Miller Challenger 172Miller Thunderbolt AC/DC 225/150Miller Maxstar 150 STLVictor 100CVictor JourneymanOxweld OAHarris O/ASmith O/A little torchNo, that's not my car.
Reply:nitrile o rings seem to hold up good..amazon has a nice supply of themYou'll find nitrile o rings used in many applications, including where oil resistance is needed or where low temperature functionality is required. ... This material has an excellent tolerance for high temperatures, resistance to oils, fuels and hydraulic fluids as well as aromatics and solvents.Oct 31, 2018Viton vs Nitrile o-Rings: What Are The Differences? | NESthis link explains the 2 and which is better for what applications..https://www.google.com/url?sa=t&rct=...ha0ZOrwTyb4cuk
Reply:What is the solvent you are using?Mike
Reply:Your local diesel injection shop will have what you need.They have orings by the 10,000snds!
Reply:If you're in the usa it's impossible to beat McMaster CarrI'd try viton, they are
Reply:When to choose Buna or Viton ElastomerPosted on December 12, 2012The choice of elastomers, rubber parts, in a pump can be very critical to the long-term success of the pump system. Pumptec provides 2 standard choices for their pumps, Buna or Viton.Buna (NBR, Nitrile) is standard in most pumps and works well in most uses in cleaning and fluid pressurizing applications. This form of synthetic rubber is generally resistant to oil, fuel, and other chemicals (the more nitrile within the polymer, the higher the resistance to oils but the lower the flexibility of the material). Buna o-rings are black.Viton is a brand of synthetic rubber and fluoropolymer elastomer commonly used in O-rings and other molded extruded goods. It is a trademark of DuPont. Pumptec uses Viton in pumps used in Pest and Lawn spraying because of its resistance to hydrocarbons found in some chemicals. Viton o-rings are brown.Owner of Fast Leroy's Bar and GrillLiquor up Front, Poker in the Rear
Reply:Best choice for brake parts cleaner, based on the ingredients in CRC Brakekleen , would be Perfluoroelastomer compound FFKM. this is going to be expensive, as far as orings go and more difficult to find. 2nd choice would be Viton Extreme compound ETP also difficult to find. Third and most practical choice would be Viton FKM. There are multiple online sources for all of these.Mike
Reply:So I took the part to a local shop and told them what the application was and they fixed me up with the Buna orings, so far working good. Thanks for all the input, I got a crash course on orings. (The oring that was in there was just rubber)Miller Challenger 172Miller Thunderbolt AC/DC 225/150Miller Maxstar 150 STLVictor 100CVictor JourneymanOxweld OAHarris O/ASmith O/A little torchNo, that's not my car.
Reply:William I don't know if he did not have Viton or if he thought Buna would be best but I wasn't about to grill him over a $1 sale and to boot the building is closed to the public due to Covid and I had to wait outside (110 degrees) while he took my part inside and fitted it up then brought it back out to me.Miller Challenger 172Miller Thunderbolt AC/DC 225/150Miller Maxstar 150 STLVictor 100CVictor JourneymanOxweld OAHarris O/ASmith O/A little torchNo, that's not my car.
Reply:Buna N (nitrile) should be ok with brake cleaner, but you'll soon find out
Viton (FKM) would be "better" but it all depends on whats in your cleaner solvents.Neither is any good for Acetone unfortunately
GMT+8, 2025-12-20 20:21 , Processed in 0.091734 second(s), 18 queries .
