Pipe miter cut help
发表于 2021-9-1 23:16:26 | 显示全部楼层 |阅读模式
I need to cut 45* angles on a pipe that's 6 5/8" OD, 1/4" thick. My blue book shows 6" pipe, marked in eighths with 1 being 2 3/8" and 2 being 3 5/16". Since it doesn't show my OD size will using the numbers for a 6" OD throw it way off? I had a hard time finding a free printable template that would accept the dimensions. Would this get me close enough to doctor the rest with a grinder? I don't need to be spot on, it's just a smoke stack for a BBQ pit/smoker so I have some wiggle room. If not can anybody tell me how to get the correct measurements?Thank you.
Reply:The measurements should be close enough. They call it 6 inch pipe, but they don't go by the OD, they go by the ID on pipe below 14 inch.
Reply:Awwwwww shoot, I knew that! That's what happens when you have to siphon bad gas out of your machine, you catch the stupids. Thanks for setting me straight.
Reply:https://uploads.tapatalk-cdn.com/201...ad4eebc55f.jpgThese things are awesome if you ever run into more complex angles. Lincoln SA-250Lincoln SW 200Miller ThunderboltSA-250 TMDSquarewave 200Thunderbolt AC/DC1951 G.E. welder
Reply:the easy way is by the book. the hard way is to. . . . 45s are easy. call the long side of your cut 0. since it is a 45 deg cut, (1:1) we know that the short side will be 6 5/8" shorter than zero. so if you punch-mark zero, and go 180 deg from that mark (1/2 the pipe circumference), and make a mark 6 5/8" shorter, you have a baseline. then you can go to marks half of half the circumference (1/4's), and make length marks half the difference between 0 and 6 5/8" (3 5/16").follow that pattern until you are comfortable connecting the dots! on 6" pipe you may section the circumference into 16ths to get accurate marks. i find that a cuttoff wheel makes cutting easier, and the bigger, the better. you can easily see the "plane" that a 6" wheel will cut vs a skinny little porta-band blade which will do all sorts of weird stuff when trying to cut miters.bosses stuff:trailblazer 325maxstar 200my stuff:sa 200fronius transpocket 180100 amp Lincoln w/f97 f350 DITKevin
Reply:Blocker, that looks pretty slick. I may have to look into one!92dlxman, thanks I appreciate the idea. Once TimmyTig cured me of the stupids I was able to get it knocked out pretty easily with my torch.  The cuts came out almost perfect, wish I could say the same for my welds though. Never have made a 5G cap that I was proud of, but I don't weld pipe often enough to get much practice.
Reply:I guess technically it was a 6G weld.
Reply:If you ever want one of the tools in my picture, they are made by curv-o-mark. Lincoln SA-250Lincoln SW 200Miller ThunderboltSA-250 TMDSquarewave 200Thunderbolt AC/DC1951 G.E. welder
Reply:I just found this pretty slick tool.  Too bad they don't come in one tool fits multiple size pipes/tubes.Lincoln, ESAB, Thermal Dynamics, Victor, Miller, Dewalt, Makita, Kalamzoo.  Hand tools, power tools, welding and cutting tools.
Reply:@ SGTGunner - source layout tools from Flange Wizard. We use several of their products for flat/round work. Precise, high-quality. Made in USA."Discovery is to see what everybody else has seen, and to think what nobody else has thought" - Albert Szent-Gyorgyi
Reply:I have never welded pipe or tube so bare with me as I learn.  I am under the impression that pipe is measured by the inside diameter while tube is measured by the outside diameter.  What am I missing here.  Do things change after a certain size of pipe?Lincoln, ESAB, Thermal Dynamics, Victor, Miller, Dewalt, Makita, Kalamzoo.  Hand tools, power tools, welding and cutting tools.
Reply:^ compare NPS, OD, and ID columns for Seamless and Welded Carbon Steel Pipe. Key on the column for 'Schedule #'."Discovery is to see what everybody else has seen, and to think what nobody else has thought" - Albert Szent-Gyorgyi
Reply:see below
Originally Posted by Blackslacks
Well not really. The 6 inch is a nominal dimension.  The od is constant and the id changes according to wall thickness.  The heavy six inch can have an id of a little over 4 inches.
Reply:Thank you ManoKaiLincoln, ESAB, Thermal Dynamics, Victor, Miller, Dewalt, Makita, Kalamzoo.  Hand tools, power tools, welding and cutting tools.
OK. I worded that clumsily and you got me. But the OP understood what I was saying, and he got his smoke stack built to his satisfaction. My bad.If you want to build your smoke stack with heavy wall pipe, YMMV.
Reply:just take a look at this video in the first post...the guy explains it great...and you will have to get your hands on the blue book to get the numbers but this is how its done.... you don't put 30 foot lenths of 6"pipe  into a bandsaw unless you have one hell of an overhead in your shop!!http://weldingweb.com/vbb/showthread.php...ng-amp-Cutting7*12 metal cutting bandsawmiller thunderbolt ac/dctig torchvictor oxy/ace cutting rig]hougen 904s mag drill...and of course theBFH!!!
Originally Posted by SGTGunner
I need to cut 45* angles on a pipe that's 6 5/8" OD, 1/4" thick. My blue book shows 6" pipe, marked in eighths with 1 being 2 3/8" and 2 being 3 5/16". Since it doesn't show my OD size will using the numbers for a 6" OD throw it way off? I had a hard time finding a free printable template that would accept the dimensions. ...Thank you.
Reply:You should learn how to mark out your own pattern, it's not difficult and you always have it with you if you are out in the field and don't have a printer or curve o mark with you.
Reply:That link was dead Zipzit. here's an alternate: http://www.metalgeek.com/static/cope.pcgiSqWave 200Millermatic 190Airco 200 ACHypertherm PM45Boice-Crane Band SawVictor O/A
GMT+8, 2025-12-19 17:53 , Processed in 0.072766 second(s), 18 queries .
