30 amps 240 volts
发表于 2021-9-1 23:16:22 | 显示全部楼层 |阅读模式
Can I weld witn 30 Amps and 240;volts with a Lincoln tombstone. Thanks Bish
Reply:It depends how many amps you are welding with. Clear as mud?Miller 211Hypertherm PM 451961 Lincoln Idealarc 250HTP 221  True Wisdom only comes from Pain.
Reply:I used to run my first Thunderbolt on a water heater breaker.I think it was 30 amps. Never tripped the breaker.But I never ranany 5/32 rod or burned rod after rod without giving it a break.Miller a/c-d/c Thunderbolt XLMillermatic 180 Purox O/ASmith Littletorch O/AHobart Champion Elite
Reply:Short runs, small rods, lower amp settings you'll be alright for small jobs.... push it and you'll be popping breakers. If you're serious about doing a lot of welding, you'll need a dedicated line and breaker. Size of the tombstone and distance from the box will determine the size of the breaker required.Last edited by whtbaron; 03-04-2021 at 10:30 AM.250 amp Miller DialArc AC/DC StickF-225 amp Forney AC Stick230 amp Sears AC StickLincoln 180C MIGVictor Medalist 350 O/ACut 50 PlasmaLes
Reply:Define Lincoln tombstone. Are you talking about an Idealarc 250, or are you taking about the Lincoln 225 cracker box welder? If you mean the idealarc (the bigger, 300+ lb welder), JohnT has answered your question. The smaller/lighter AC/DC 225 will run on 30 amps no problem.Miller Multimatic 255
GMT+8, 2025-12-19 17:53 , Processed in 0.105676 second(s), 18 queries .
