Q. Lincoln 255 wirematic wish to wire an hour meter , what is solenoid valve voltage?
发表于 2021-9-1 23:16:21 | 显示全部楼层 |阅读模式
I know, i can spend a few hours and dig some answers from the web or take a few minutes and get the right answer here..
So to keep track with a little more accuracy than a yearly cost of welding gaz, wire and repairs. I wish to install the easyest way possible  an hour meter either on the soleoid valve or the drive motor (i think this one is dc) or anywhere there is a current output when trigger is activated. preferably 115 volts. Any toughts, suggestions do and don't?
thank-you
GMT+8, 2025-12-19 17:51 , Processed in 0.095451 second(s), 18 queries .
