Consequences due to lack of penetration because of inexperience welders.
发表于 2021-9-1 23:16:18 | 显示全部楼层 |阅读模式
A couple of months ago we had some high wind gust and it literally blew down a 50ft hanger door. Luckily there was nobody close to the door at the time or people could have been killed. Below are some pictures of the door laying on the hangar floor and the quality of welds on the door including the welds that had virtually no penetration and they broke and caused the entire door to buckle and fall. Some of the welds apparently were so bad that they ground a lot of them down.
My Youtube Channel
https://My Youtube Channel
Reply:I guess the supervisor or inspector for the welding was out for a long lunch the day it was done...??
Reply:Looks like it was some of that hi-speed welding again, that's what the low bidders have to do when they realize their bid was about half what it's actually gonna cost them to do the job.***********************CR
Reply:Some of those look like repair welds done long after the initial construction.... could be the initial welds were bad anyways but whoever did the repair obviously did not know how to do it even close to right.
Reply:Speedy Erection Company.. About pic 5 down, I see a couple of bolted connections that didn't age well either. Piece number 230. They either wore clear through to the edge over a period of time or tore out all at once. Who knows. There should be a record somewhere of the building manufacturer and maybe even the contractor."The things that will destroy America are prosperity at any price, peace at any price, safety first instead of duty first, the love of soft living and the get rich quick theory of life." -Theodore Roosevelt
Reply:could be the whole place is a hazard/screwed up
Reply:^^ Probably more true than anyone wants to acknowledge....But then again texas sure gets it's share of high winds with really high gusts!!!  about 4 months ago they lost part of the roof at one of the hangars at love field and I think right on a year ago hobby lost a whole hangar!!!
don't think I'd want to be in a hangar around there when a storm blows through!!!
Reply:Its got to be trumps fault! Im not sure how but I am sure a few dems will chime in on how it his fault.
Reply:He cut funding to the FAA!!!!on the other hand look how many hangars are in texas and how many have failed.... still safer than driving a car on the interstate
Reply:When our new Ambulance station was built all the welds were done with a 120 volt flux core welder, by the same guys that screwed all the sheet metal on and erected the frame. It was all for metal frame entrance doors but the welds all looked like crap and little penetration as they looked like they were just "piled up" on the steel.IMPEACH BIDEN!NRA LIFE MEMBERUNITWELD 175 AMP 3 IN1 DCMIDSTATES 300 AMP AC MACHINEGOD HELP AMERICA!“Freedom is never more than one generation away from extinction.We didn’t pass it to our children in the bloodstream".RONALD REAGAN
Reply:So, where do you go from here?  At the very least if it where I, and the building was mine, I would be wanting to check all welds in the building first to see if it is safe to continue use.  Really sad to see this kind of work.  Building department would probably be the first place to look as they would have the permit info and builders info.  Going to take some work for the research.  But for now, management better get hopping and a quick search and repair is in order.  If you are an employee there, bet this will be haunting you wondering what else is going to come apart.  Bob
Reply:Just be thankful you guys don't get snow.12v battery, jumper cables, and a 6013.I only have a facebook page. https://www.facebook.com/pages/VPT/244788508917829
Reply:looks mostly big joint gap, filled poorly. and of course if you got a 1/4" gap and suppose to put 3/8" fillet weld obviously you need to make weld bigger cause very little strength in the filled gap..you have a small weld and that where the forces get concentrated. aint no different if you got a 1/2" plate and part of the plate is only 1/4" thick so if you bend the plate if bends at the 1/4 to 1/2 transition. and of course if 6010 used on A36 the weld is slightly weaker than the A36 steel. another reason weld needs to be bigger..if weld under sized and there was severe whipping done to fill gap its probably got oxidation and slag inclusions in weld too..and of course if fillet weld only from one side than 1/2 plate would need a .75" fillet weld to match strength and thats assuming no joint gap. if 1/4 gap more like 1" fillet weldLast edited by WNY_TomB; 07-23-2019 at 09:31 AM.
Originally Posted by ronsii
Harbor freight welder ????
Reply:even bad welding will hold up until it doesn't.  the door square footage in addition to the stress from high winds found every weak spot. mother nature is a mf'er of a weld inspector.i.u.o.e. # 15queens, ny and sunny fla
Reply:on every job of any size or especially for a port authority or public utility the first thing i had to do after filling out a tax form was show my welding creds. over the year's i can't count how many times my nyc dob welding license/fire department certificate of fitness and aws d1.1 was copied and filed. this procedure should be sop so if there was any inexperienced welders that can be tied to that door failure they shouldn't be hard to track down. let the lawsuits commence.i.u.o.e. # 15queens, ny and sunny fla
Reply:I would like to be there when the insurance adjuster comes and hear what his take is on it.  Bob
Reply:Next political comment in this thread gets it locked.Do ya really want that????There is a place for it conveniently set up here for that sh!t.Use it.That is all.Carry on....zap!
I am not completely insane..Some parts are missing
Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:All good answers, yet it was Mother Nature, who can put a piece of straw through a Oak tree
Reply:Climate change.12v battery, jumper cables, and a 6013.I only have a facebook page. https://www.facebook.com/pages/VPT/244788508917829
Reply:BB Ford FE. Single or dual plane ?It looks to me like they only put one pass on each joint. Good or bad didn’t make any difference.
Originally Posted by 737mechanic
A couple of months ago we had some high wind gust and it literally blew down a 50ft hanger door. Luckily there was nobody close to the door at the time or people could have been killed. Below are some pictures of the door laying on the hangar floor and the quality of welds on the door including the welds that had virtually no penetration and they broke and caused the entire door to buckle and fall. Some of the welds apparently were so bad that they ground a lot of them down.]
Reply:Looks like a design problem with those tabs that broke only welded to the outer flanges of the channel, even with good welds that's a wimpy connection for the amount of force a wind load would put on that door.Last edited by CrookedRoads; 07-28-2019 at 11:28 AM.***********************CR
Reply:The Op said it was a 50 foot door. Viewing the pic, the height looks about 34 foot counting 4 foot joints were the blue insulation stuf is now exposed. That comes out to about 1,700 square feet. That's a bigger footprint than my house. Big pressure differences between outside and inside happen. That's why those buildings flex or have flex joints so the roof can lift and lower with changes. Wind causes pressure changes. Ever see an exterior or interior door slam open or shut real hard?I'm no cwi so I have no comment on the welds.
Reply:I hope the guy that welded that door didn't also weld the crane hangers Sent from my SM-G960U1 using Tapatalk
Reply:Some bad design/detailing too - bending about the longitudinal axis of a weld is not good.
And that bolt would have elongated a bunch to result in that amount of plate prying.
LINCOLNSquare Wave TIG 200Power MIG 210 MPRanger 330 MPXMILLERThunderbolt AC/DCHYPERTHERMPowermax 190CPowermax 45XPHOUGANHMD 130HMD 505FEIN/SLUGGER 14" COLD METAL CHOP SAW 9" COLD METAL HAND-HELD SAW
Originally Posted by Oscar
Oh I wouldn't call that entirely Mother Nature.  Gravity has a lot to do with it as well, and exists beyond this world into all reaches of the universe, and even spills over into the next universe.
Reply:The "design" (if that garbage actually conformed to print) is clearly negligent, the welding is worse and someone needs jail time.  First week welding students with no prior experience could turn out better welds.  I've seen them do it.  Some of those welds are colder than a tax man's heart. I hope the guy that welded that door didn't also weld the crane hangers
GMT+8, 2025-12-19 17:51 , Processed in 0.095816 second(s), 18 queries .
