Optrel E684 Cheaters
发表于 2021-9-1 23:16:17 | 显示全部楼层 |阅读模式
Does the E684 takes the same size cheaters as just about everybody else? The Optrel branded costs about 3 times as much.
Reply:I'm not sure how the 684 retains its inner lens, but I'd like to assume the retention mechsnism is the same as my 680. The optrel cheater I have in mine has thinner recesses along the vertical edges to allow it to slide up into the frame, due to being thicker for the magnifying feature. Afaik, the generic cheaters don't have that. You could maybe dremmel the edges of the cheap ones out to fit. Eta: I believe the optrel inner lenses are a hair bigger in both directions than generic ones.Last edited by Tango Sierra; 10-16-2019 at 01:30 AM.Reason: Clarity
Reply:Hi Wolfman,standard cheater does not fit the E684. You may be able to modify, I think you'd have to mill in a step, but personally I don't think it's worth it. You only need to buy one and it's not a big deal in the scheme of things, you soon forget about the few extra bucks and move on. The Optrel cheater is plastic (not glass) so there's that, and it comes with a thin plastic bar to seal up the remaining gap. 10 seconds after fitting, this bar falls out and you throw it away because it's not needed anyway. I've been using the Optrel cheater in my hood for a while now and it's quite good for plastic. I run a glass cheater (from Honkers) in my back up el-cheapo bucket helmet.
GMT+8, 2025-12-19 17:51 , Processed in 0.075930 second(s), 18 queries .
