Just great dayhttps://www.bing.com/images/search?v...2,4,6,8&sim=11Why a great day He walk awayDaveHF 170 welderHF 4x6 band sawSouth Bend 9NMillB&D mag drillVictor torch
Reply:wow....lucky guyGreggHobart Handler 210 MVPHobart Stickmate 210i
Reply:Saw a guy get a broken jaw cutting 6" pipe, he pulled it up out of the trench with the crane on his truck and obviously didn't think it out. I had to take a section out of a 24" line to install a gate valve on top of a hill once, expecting the same result we cribbed the pipe and held it down with 2 large excavators. We still had some movement, not much and the beveling rig rode it out just fine.
Reply:lesson learned the hard way.i.u.o.e. # 15queens, ny and sunny fla
Reply:Bet he isn’t constipated anymore
Reply:How does one cut a pipe like that safely with out having to worry about the built up spring in the pipe?Lincoln, ESAB, Thermal Dynamics, Victor, Miller, Dewalt, Makita, Kalamzoo. Hand tools, power tools, welding and cutting tools.
Reply:Big pipe like that can build up big forces as seen. The excavators was a good idea. You could also weld some serious threaded dogs over already cut sections to hold it with bolts and when fully cut wind the bolts out.
Originally Posted by docwelder
have the helper cut it
