查看: 13|回复: 0
Will this respirator fit under my Miller helmet?
发表于 2021-9-1 23:16:16 | 显示全部楼层 |阅读模式
I weld a lot in our garage, where ventilation isn't optimum, and want to get some kind of respirator. I don't weld aluminum, galvanized or stainless, just steel, and occasionally a little iron.  But I often weld "dirty" metal, often with paint on it (e.g. red oxide primer). I have a Miller Digital Performance helmet.  Will this respirator fit under it?  I like this kind so I can use the 2097/2297 P100 filters. It's at Home Depot. Its web page is at: https://www.homedepot.com/p/3M-Mediu...A1-A/202078789p.s. that's not me in the picture!
Last edited by Ruark; 12-28-2019 at 12:41 PM.-RuarkLincoln 3200HDHobart Stickmate LX235TWECO Fabricator 211i
Reply:I wear one of those under my Miller Digital Infinity with no problem Sent from my SM-G930V using TapatalkMillermatic 252 MIGMiller Dynasty 200DX TIGMiller Spectrum 625 PlasmaAltas 12x36 Metal LatheBridgeport Milling Machinewww.psacustomcreations.com
Reply:No problem. You really should wear the dust mask when grinding. I try to put mine on whenever I grind and it makes a big difference in how I feel later in the day compared to when I am lazy and don't put it on.Millermatic 252 MIGMiller Dynasty 200DX TIGMiller Spectrum 625 PlasmaAltas 12x36 Metal LatheBridgeport Milling Machinewww.psacustomcreations.com
GMT+8, 2025-12-19 17:53 , Processed in 0.088054 second(s), 18 queries .
