Want to read something written by a bot about welding?
发表于 2021-9-1 23:16:14 | 显示全部楼层 |阅读模式
Bots come to the world of welding:https://prowelderguide.com/mig-vs-ti...which-is-best/
Reply:I did not read the entire article. What I did read was some incoherent repetitive BS.Did I mention nonsense?Ernie F.
Reply:I've been seeing a lot of that kind of thing lately. Can you imagine doing that for a living?
Reply:Scary, just scary to think that someone would base what they found as information for a purchase (the very purpose for that page)"You can weld some aluminum with a mild steel wire, but this is not always suitable.Welding aluminum with mild steel wire will increase the chance of porosity and a higher chance of cracking.In MIG welding, you will never have to worry about gas and shielding gas because MIG welding uses a wire that contains all the necessary ingredients needed for the weld.If you are using a MIG welder, you’ll want to use an aluminum shielding gas. If you are using TIG, you’ll want to use aluminum wire."
Reply:Great info there. So if I want to MIG weld 1/4" aluminum I should use .255 diameter mild steel wire????Awesome.---Meltedmetal
Reply:What's even scarier is someone unfamiliar or a newbie might take it as useful information. I've seen bad information or even mis-information but that takes the cake!
Reply:......Last edited by Kelvin; 06-25-2021 at 07:32 PM.
GMT+8, 2025-12-19 17:50 , Processed in 0.086469 second(s), 18 queries .
