Mig Welder Voltage?
发表于 2021-9-1 23:16:13 | 显示全部楼层 |阅读模式
I have a Thermal Arc 211 Multi-Process mig welder. I noticed that if I set the voltage.....at say.....22 volts sometimes the welder will show 25 volts or so after welding. Any idea why this is?
Reply:Wonder if the setting is approximate and after welding shows the actual voltage?
Reply:My thermalarc tig does the same thing Sent from my SM-G960U using TapatalkI haven't built anything I can't throw away.  Perfection is the journey.    Mac
GMT+8, 2025-12-19 17:51 , Processed in 0.091429 second(s), 18 queries .
