Welding home gym
发表于 2021-9-1 23:16:12 | 显示全部楼层 |阅读模式
I want to weld an outdoor home gym with stations for pullups, bar dips and push up bars, all attached to some cedar posts. I want to use 1 1/4 inch black pipe and weld these to plates that I would attach to the wooden posts. I also want to weld pipe to pipe at 90 and 45 degree angles. These are all structural pipe welds, unlike most of the pipe welding talked about on this forum. I chose black pipe over galvanized because it is easier to weld, cheaper and does not give off fumes when welded. I will need to paint it. Would anyone choose galvanized pipe over black pipe?As a structural weld for this size of pipe, what would you use? MIG or stick? I was thinking stick. I assume mild steel plate would weld fine to black pipe using either stick or MIG. The welds I plan will be pipe to plate at 90 degrees, and pipe to pipe at 90 and 45 degrees. No pipe to pipe to extend the length like on a pipe line and all of it is to bear my weight while exercising. Any advice on technique would be appreciated. Sent from my iPhone using Tapatalk
Reply:One suggestion is wherever you can, utilize screw on pipe flanges to attach bars to your wooden posts. It may make for a tidier looking structure than all welded. Sent from my iPhone using Tapatalk:
Reply:I would use mig myself. Main thing is getting a good fitup on your cope joints. If you've never coped pipe before I would recommend the pipe master coping tool or I believe you can print out patterns for various joints online. Google pipe coping templates.
Reply:Pipe and other material sizes TOTALLY depend on your strength,, now, and after a few months of exercise,,I know guys that would destroy the material sizes you mentioned, and they have not exercised that long.As far as choosing black, galvanized, etc,,,,,,  I would base my selection on the minimum prep and maintenance for use.Some galvanized is used on playground equipment every day,, but, I have seen the stuff at the big box stores with flakes of zinc coming off.The last thing you want is flakes of zinc imbedded in your hands.The same goes for black steel pipe, not all pipe is manufactured to be touched constantly, it is made to carry gas,,I think that is why LOTS of exercise equipment is built with specialty material,, As far as welding zinc,, people do it every day,, it is mostly only a problem if you ignore the fumes.Be down wind, you will be fine.  It is not like you are welding inside the Chernobyl power plant,,
Reply:MIG or stick, whichever process you want.Black pipe welds up nicely but it is covered in protective oil:Joint areas goes without saying but also consider that  you'll need to really clean ALL of  it before painting.Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:For coping pipe at 90° joints, I often cut two 45° angles on one piece (the base of the "T" joint so to speak) to create a bird's mouth and that gets it "good enough" to bodge it together with stick welding...and if I want it to be good and strong, I'll generally use 6010 rod, even though it doesn't look as good (and isn't as tough) as 7018, because it penetrates a bit better (and fills gaps easier)...
Reply:Here are pics of a few bars I've built for ideas...One inch diameter solid round stock. Mig welded. Bends made in hydraulic press. Chrome plated. One inch silicone heater hose and one inch locking shaft collars for grips.
2" pipe (for fat grip)  also mig welded and chrome plated.
1.25"D pipe "handle bars" for T-Bar row. Bends created with pipe bender in hydraulic press. Mig welded also. "Grip" surface created using black automotive rocker guard coating.
Originally Posted by Broccoli1
The pipe flanges are like 7-8 bux a piece right now.Was at Lowes looking for some last week.
Originally Posted by Welder Dave
Pipe Master's are great, especially for things like roll bars in race cars where several pipes meet at odd angles. The one thing I would do is buy structural pipe/tubing from a steel supplier instead of the water/gas pipe they sell at box stores like Home Depot. The black pipe can be quite rough and who want's to spend all the time cleaning and polishing it to get it smooth. Mig would be fine for welding as long as you have the required skill. Same with stick. It's not a first project for when you just got a welder.
Reply:I could get a screw on pipe flange for one side, but the other side has to be cut to fit the other post, so it wont have threads.  I could thread it, but I thought welding would be easier. Those bars and welds look nice. Do you use that equipment yourself?The reason I am building instead of buying is that I want an outdoor workout place and will use my own weight for most of the exercises. I have cedar trees that I can cut with a sawmill for the posts. I wanted bars that I could weld and would not rust. I will look for pipe railing. Sent from my iPhone using Tapatalk
Reply:I think welding looks more professional than threaded pieces. Was in a take out fast food place and the railing (upper and middle rail) to keep people in line behind the counter was made with all threaded pipe connections. Looked like it was some last minute idea. Probably took a while to figure out all the length's of pipe (and the order to assemble them) so they would thread together. Would have been a good exercise in school for an apprentice but not for an actual job.Last edited by Welder Dave; 06-30-2021 at 03:58 PM.
Reply:I will try to find pictures of some of my stuff when I get home. Go to Reebz Welding on face book, should be a bunch of pictures. It may give you some ideas. I used to do a ton of this type of work.
Reply:I wouldn't dick around with any threaded stuff. All the stress is applied to an area that is weakened from the reduced wall thickness at the valley of the thread.
Reply:Welding around ready rod is the same thing. The threads are like the starting point for cracks.
Reply:Depending on your design you may be able to drill the correct diameter hole through your posts for the pipe.  This may minimize your welding. Just found this on Google images….
Sent from my iPad using Tapatalk
Reply:I would likely go with stick given the size of the material.  Welding around small diameter cylinders accurately is difficult, stick gives that little extra bit of access/maneuverability.I might go with mig if most of the welding was done on a bench or on rollers (not in place).I would have the bar go through the post and be secured preferably on both sides ("capturing the post"), or at the very least use through bolts (not screws/lags) to attach flange to post.  The dynamic loads on this could be pretty large.Be sure to check and re tighten things as the wood dries out/settles.Consider going with solid instead of hollow material - overkill is best when anything living is the intended load.  Also, solid material can be bent (Easy when heated, and can be heated by literally just a small bbq or bonfire).Last edited by SlowBlues; 07-01-2021 at 09:08 AM.
Reply:There's going to be a tendency, on the posts in the pic Lis linked, for the posts to split, with the round pipes acting as wedges. I'd find a way to address / prevent that.
Reply:If going through the wood with the bar I'd suggest over sizing the hole and using PL premium or similar between the wood and metal.  Even if no glue is used for the metal I would use a little lightly thinned wood glue for the ends and any holes (to help prevent future cracks), and in present cracks.the wood will expand and contract being outdoors, in addition to the first acclimatizing.
Reply:You could drill the wood post holes slightly oversized and screw NON threaded pipe flanges on either side of the post to capture the pull up bar. This should mitigate the post from splitting, add additional support, allow the capability to remove by loosening the set screws, AND  look relatively professional.
GMT+8, 2025-12-19 17:50 , Processed in 0.107306 second(s), 18 queries .
