Concession Trailer Build Advice
发表于 2021-9-1 23:16:08 | 显示全部楼层 |阅读模式
I have been asked to frame out the walls and roof of a 20’ long trailer that is destined to be converted into a concession trailer.I have built modular type walls using 1 1/2” 14ga square tubing, but nobody was going to drive them down the highway.I was thinking 2x2x1/8” square tubing for this project.Any advice on my choice from those who might have built similar trailers??Thanks!!Hobart Beta-Mig 2511972 Miller AEAD-200LEMiller 250 TwinNorthern Ind. Hybrid 200Longevity Stick 140Longevity Migweld 200SThermal Arc Pak 3XR
Reply:Have you calculated weight? And estimated weight loaded. I built a axe throwing cage on a 24 ft trailer.  Did 14g.  2x2Weight and design would dictate lighter metal.
Reply:I would check out Joe's build for ideas. His trailer turned out pretty nice and has been in use for a couple of years
Reply:Work is work, but sometimes trailer add-ons aren't the best. I would see what concession trailer manufacturers use and copy. Knowing what his intentions are for use can impact build. I'm thinking like roof vents, side wall swing open canopy, cabinets, sink, table, water storage, electricity, etc. Knowing the final usage will definitely impact building. With what material costs, he may consider trying to find a use one. Sent from my iPhone using Tapatalk
Originally Posted by Lis2323
I agree with BD1 about the build. Not to derail the topic but as rule I will not eat anything from a concession truck.   It is extremely difficult to maintain good food safe procedures in a limited space and small prep and utensil cleaning areas.
Originally Posted by Louie1961
You worry too much. Questionable food just strengthens your immune system!  ;-)
Nah. I just like to bitch.
I agree with BD1 about the build. Not to derail the topic but as rule I will not eat anything from a concession truck.   It is extremely difficult to maintain good food safe procedures in a limited space and small prep and utensil cleaning areas. Sent from my iPad using Tapatalk
GMT+8, 2025-12-19 19:23 , Processed in 0.147999 second(s), 18 queries .
