Aluminum roller tool box
发表于 2021-9-1 23:16:07 | 显示全部楼层 |阅读模式
Plan on giving it suspension and it’s a 1/4” top that I’ll add some angle on for support and drawers in the future. Plan on using 3”’casters
need it done by Monday. I was thinking tig brazing the valve spring
Reply:Getting there
used my 312 super missile rod and it went great. No cracking at all on the fusion tacks. Got 3” casters today and it should be rolling tomorrow after I drill the 32 holes to 1/4”. Probably gona use 4” flat bar for the sides
Reply:nice job, i like light stuff, that can easily be thrown on back of pickup.
Reply:Round is easier on the ankles when you kick the plates accidentally.
12v battery, jumper cables, and a 6013.I only have a facebook page. https://www.facebook.com/pages/VPT/244788508917829
still a work in progress. Need 7’ of 3” aluminum flat bar to go around the top.
Reply:Looks like the kiddos have inspected it and approved
Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:motolife,why did you add suspension to the legs/casters?  If you said (already) and I missed it;  sorry to ask the obvious.Tool box on top and drawers in 'kids cargo bay'?Cheers,Kevin MorinKenai, AK
Originally Posted by Welder Dave
The kids like it but the top pic. looks like it should be in some kind of safety manual where you have to point out the potential hazards.
Reply:Suspension is for a smooth ride I’m going to get some stuff for it and add stuff to it this weekend. I’d like a drawer on the bottom since it’s already a little top heavy since it isn’t very wide the narrow way. It will be getting lots of hooks. I was thinking dirtbike handle bars for the handle to push it.
Reply:Went shopping at the metal yard today and got some 2” flat bar and found some bent pieces of aluminum to be used as hooks and handles. Didn’t wipe nothing down or brush nothing
GMT+8, 2025-12-19 19:25 , Processed in 0.094436 second(s), 18 queries .
